Why Isn't the Universe Just a Big Black Hole?
The discussion revolves around the question of why the universe is not considered to be a large black hole, exploring concepts related to cosmic expansion, inflation, and the nature of the universe's mass distribution. Participants engage in theoretical reasoning and challenge each other's perspectives on the implications of the universe's expansion and its early conditions.
  • Some participants propose that the universe's expansion in its early stages was so rapid that gravity could not prevent it from expanding, questioning why all mass did not collapse into a black hole.
  • Others argue that the concept of inflation allows for the universe to have been infinite at the beginning, suggesting that local density could become infinite without the universe needing to be confined to a single point.
  • A participant mentions the idea of a superluminal inflationary epoch, which, while seemingly contradictory to relativity, is explained as the expansion of 'empty' space.
  • There is a discussion about the energy dynamics during inflation, with some suggesting that the total energy of the universe could have been zero or nearly zero, and how this relates to the gravitational field's energy compensating for matter's energy.
  • Concerns are raised about the speculative nature of some explanations, particularly regarding energy conservation and the role of the gravitational field during inflation.
  • Some participants express confusion about the implications of inflation and the nature of the universe's early conditions, indicating a lack of clarity on the topic.
  • There is mention of the Big Bang Theory (BBT) as the best explanation for existing observational evidence, while acknowledging that it is not without its critics.
Participants express a range of views, with no consensus reached on the nature of the universe's expansion and its implications for black hole formation. Some agree on the speculative aspects of certain theories, while others challenge the interpretations presented.
Participants note the complexity of the concepts discussed, including the non-linear nature of inflation and the speculative nature of energy dynamics in the early universe. The discussion highlights the challenges in understanding these advanced topics without resolving the underlying uncertainties.
blue_sky
Why the universe is not a big black hole?
Why should it be?
Because it is an elegant hypothesis ?
EL said:
Why should it be?
The universe expansion means that in the past all the mass was concentrated; why that mass didn't collapse in a huge BH?
The rate of expansion was incredibly fast in the very early universe. To put this in perspective, by the time the universe was 3 minutes old, it had expanded to a size of ~30 light years. Gravity, weakling that it is, could barely slow the thing down, much less stop it. The battle was about as evenly matched as a tug-of-war between an ant and a locomotive. While the inexorable tug of gravity has been slowly gaining ground [actually, it may have started losing ground again awhile back], expansion is still winning the battle to this day. Current observational data suggests this trend will continue indefinitely.
Maybe this only sounds odd to me, but...
[tex] \frac{30 light years}{3 minutes} = \frac{10 light years}{1 minute}[/tex]
Now I'm assuming that you were aware of this when you posted it chronos, so please explain...
edit: taking a shot at your location...Iowa? or Missouri maybe...
so ? :confused:
What is the contradiction here ?
OK, now I understand what you mean...
chronos gave a good explanation.
I still don't get it. This is definitely the worse day in a long time for me. Inflation is certainly not a linear process is it ?
Sorry humanino. I of course ment CHRONOS gave a good explanation. Not franznietzsche (who I have no idea what he is talking about...)
Well thank you very much for this precision EL, I was beginning to think that reason was failing me. Hard day :frown:
1] Modern theory calls for a superluminal inflationary epoch in the early universe. While, at a glance, this appears to violate relativity, it actually does not. It was 'empty' space that was expanding. Hubble's constant gives us a yardstick to measure the historical rate of expansion.
2] about an hour from St Louis.
Sorry, but I don't understand. Considering the overall mass of the universe it seems to me that going back in time the universe should be all confined inside the event orizont. So, whatever was the "superluminal inflationary epoch", nothing can escape from a BH event orizont... or I miss something?
I am trying to answer, and since I am likely to go wrong, I would appreciate to be corrected. Thanks for helping me in that case.
As far as I understand, Chronos last post above answers your question : it is the space-time that is expanding. It is probably the most difficult thing to understand, because this misconception occurs all the time. For instance, the universe could be infinite at the beginning of time. Imagine an infinite pudding in which expansion makes the berries getting far from each other : if you go back in time, the pudding never needs to be a single spot. It can be infinite all along, yet the local density can become infinite too.
An horizon occur where "light rays turn in circle". Inside the horizon, space and time are sort of "swapped". No such thing happens in the early universe, because inflation is such a violent phenomenon. Inflation is meant produce enough room to explain the homogeneity of the CB. If some sort of inflation occurred inside a BH, the singularity and the horizon would eventually disappear.
It seams to me that if the whole energy of matter in the current universe were confined nearly into a point, then you may be right.
But the total energy of the universe before inflation could have been zero or nearly zero (it doesn't really matter). During inflation the scalar field driving the expansion (inflaton) accumulated energy in its vacuum state (its energy density was constant and the volume increased).
If one wants to take into account energy conservation, this energy might have been compensated by the energy of its own gravitational field (this is a negative value). After inflation the accumulated energy was transferred to the matter field in a process called reheating.
I think this is an accepted possibility, but to me it seams very speculative and not necessarily correctly defined.
Of course it is speculative. Even some professional scientists question big bang theory [BBT]. It is, however, the best explanation to existing observational evidence: of which there is a great deal. If you think BBT is weird, try quantum physics. Now that stuff is downright 'spooky'. Still, a lot of people believe it because it works really, really good.
:smile:
Seriously, is there any serious competitor to BBT ?
AFAIK, none has been as successful on several facts, among which :
redshift
CMB
relative abundance
Of course, Einstein himself questionned BBT, and was even against at the beginning.
I did not question the big-bang theory, but the hypothesis that the energy accumulated into the gravitational field compensates (more or less exactly) the energy of matter in the universe.
Apologies, I misunderstood your question. The concept of gravity as negative energy has to do with the conservation of energy law and how the universe has managed to avoid being in violation. Stephen Hawking gave this explanation:
"The answer is that the total energy of the universe is exactly zero. The matter in the universe is made out of positive energy. However, the matter is all attracting itself by gravity. Two pieces of matter that are close to each other have less energy than the same two pieces a long way apart, because you have to expend energy to separate them against the gravitational force that is pulling them together. Thus, in a sense, the gravitational field has negative energy. In the case of a universe that is approximately uniform in space, one can show that this negative gravitational energy exactly cancels the positive energy represented by the matter. So the total energy of the universe is zero."
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 31 ·
  • · Replies 22 ·
  • · Replies 31 ·
  • · Replies 40 ·
  • · Replies 17 ·
