Calculating Fluid Friction in a Spiraling Tube of Varying Diameter and Shape
  • Context: Graduate
  • Thread starter Thread starter Ameriu
    Fluid Friction
The discussion revolves around calculating fluid friction in a spiraling tube with varying diameter and shape, specifically focusing on the challenges posed by the geometry of an Archimedean spiral. Participants explore the relationship between fluid dynamics and the physical characteristics of the tube, including changes in diameter and cross-sectional shape.
  • One participant inquires about calculating fluid friction in a narrowing tube shaped like an Archimedean spiral, noting the lack of specific resources addressing the geometry involved.
  • Another participant suggests that the relationship between fluid pressure and speed should be considered, recommending the Navier-Stokes equation as a relevant tool.
  • A different viewpoint proposes segmenting the pipe into smaller sections to calculate pressure drops, depending on the smoothness of diameter and angle changes.
  • Another participant introduces the Hazen-Williams empirical formula for turbulent flow as a potential method for calculating pressure drops in a continuously decreasing pipe diameter, while noting its applicability to the spiral shape under certain conditions.
  • Discussion includes the importance of the roughness coefficient and its dependence on the Reynolds number of the flow.
Participants express various approaches to the problem, with no consensus on a single method or solution. Multiple competing views and techniques are presented, reflecting the complexity of the topic.
Participants highlight the need for careful consideration of the geometry of the tube, including abrupt changes in diameter and angle, and the implications for fluid dynamics calculations. Limitations in existing formulas and the need for iterative methods are also noted.
This discussion may be of interest to those studying fluid dynamics, engineering applications involving fluid flow in complex geometries, and researchers exploring empirical methods for pressure drop calculations in varying pipe shapes.
Ameriu
Well, yes, this is my first post here, and I do hope I got it into the right section (And no, this is not homework, and although I was thinking of posting it there; I also considered posting it in the engineering forum, but I believe it would fit better in general physics forum).
Would it be possible to calculate fluid friction against the walls of the tube, if it is moving within a narrowing pipe/tube, which is laid in a fashion that resembles Archimedean Spiral?
I've been looking for the solution for past few days, yet most of the fluid friction topics describe drag friction, or contain very vague formulas for "water friction against pipes", but none of the really let me take into the account the decreasing diameter and increasing angle of piping.
Additionally, how would that friction change according to the cross-section of the tube/piping (square/oval etc.)
Any directions on where to look for the solution of this problem would be appreciated!
My first post too! I think you are more interested in the relationship between the pressure of the fluid and the speed of the fluid as the volume of the conatainer changes. I would check out the Navier-Stokes equation.
If the changes in the diameter and angle are not too steep you can solve it by diving the pipe length to few (the more the better) segments with diameter of the average diameter in that segment, and then find the pressure drop for this segment and after that sum the pressure drops of all the segments.
If the changes in the diameter and angle are abrupt you can try solving it as a series of minor losses of bends and gradual contraction. Check this link for example for the minor losses - http://udel.edu/~inamdar/EGTE215/Minor_loss.pdf
The Hazen-Williams empirical formula for turbulent flow in pipes (tubes) can be used for calculating the pressure drop in a continuously decreasing pipe diameter (using an iterative program like FORTRAN):
http://en.wikipedia.org/wiki/Hazen–Williams_equation
This is probably a reasonable approximation for an Archimedes spiral, as long as the radius of the bend is large compared to the pipe diameter a any point.
The roughness (friction) coefficient depends on the Reynolds number of the flow. See
http://www.google.com/url?sa=t&source=web&cd=54&ved=0CCgQFjADODI&url=http%3A%2F%2Fudel.edu%2F~inamdar%2FEGTE215%2FLaminar_turbulent.pdf&ei=5rZuTL71Do-isAOc6qmiCw&usg=AFQjCNGighgb2ILl0zNI-EzgHnGsc5zWww&sig2=HBiWDv42IUVNv9vX-Fo2GA
Bob S
Thank you, this seems like the right piece of information I needed!
  • · Replies 104 ·
13K
  • · Replies 31 ·
