Probability Density in Quantum Mechanics
The discussion revolves around the probability density associated with a wave function for a free particle in one dimension within the context of quantum mechanics. Participants are exploring the concepts of wave functions, probability densities, and normalization.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are attempting to construct the probability density from the wave function and are questioning the limits of integration for normalization. There is confusion regarding the nature of the probability density as a function versus a numerical value. Some participants are exploring the implications of the wave function being complex and the effects of normalization when considering different spatial constraints.
The discussion is active, with participants expressing confusion about normalization and the characteristics of the probability density. Some guidance has been offered regarding the relationship between the wave function and its amplitude, as well as the implications of the particle being contained within a specific region.
There are ongoing questions about the assumptions related to the wave function's normalization, particularly in the context of infinite versus finite regions. Participants are also considering the implications of a constant probability density and its graphical representation.
JamesJames
Consider the wave function corresponding to a free particle in one dimension. Construct the probability density and graph it as a function of position. Is this wavefunction normalizable?
Now, I think that the function should be Psi = C1*exp(ikx-iEt). Thus, the probability density should be the integral over x of C1^2. What I am confused about is what are the limits of the integration...0 and inifinity? And also won' t the answer come out to be a constant if the upper limit is not infinity ? I am totally lost on the normalizable issue. :confused:
Thanks,
james
A probability density is NOT an integral- it is the density function itself which is what you give. The probability density is not a number, it is a function.
So, it should then be
[C1*exp(ikx-iEt)][C1*exp(-ikx+iEt)] which equals C1^2. I don' t see how you can get a function and what about the normalization question?
Any help would be great
Note, your C1 may be complex.
With regard to normalization, if you KNOW your particle is absolutely contained in some region then [itex]\left| C1\right|^2 = \frac {1}{L}[/itex] where L is the size (length) of the region. Ask yourself what happens when L tends toward infinity.
I am still confused about the normalization...does it have to be of length L? Also the probability density would then produce a straight line rather than some curve which seems unusual to me.
Normalization means that you want to find the amplitude of the wave function and you do that by requiring the probability of finding the particle anywhere to be 1. If you KNOW it's in a box then the size of the box will be part of the normalization.
  • · Replies 25 ·
  • · Replies 23 ·
