How Do You Calculate the Mass of an Ion in a Magnetic Field?
  • Thread starter Thread starter Clay
    Figure
The mass of a singly charged heavy ion in a magnetic field can be calculated using the formula derived from equating centripetal force to magnetic force. Given a magnetic field strength of 0.053 T and the ion completing five revolutions in 1.58 ms, the charge of the ion is equivalent to the charge of an electron, 1.6 × 10-19C. The mass was calculated as 4.28 × 10-25 kg by rearranging the equation m = (qBr)/v, where the velocity was determined from the time per revolution.
  • Understanding of centripetal force and magnetic force concepts
  • Familiarity with the equation qvB = (mv²)/r
  • Basic knowledge of circular motion and frequency calculations
  • Knowledge of charge units, specifically the charge of an electron (1.6 × 10-19C)
  • Study the relationship between magnetic fields and charged particles in motion
  • Learn about the principles of circular motion in physics
  • Explore the concept of frequency and its calculations in circular paths
  • Investigate the properties of ions, including charge states and their implications
Students in non-calculus physics courses, educators teaching electromagnetism, and anyone interested in the dynamics of charged particles in magnetic fields.
Clay
Hi everybody. I'm taking non-calculus physics at NCSU. There is a tricky homework question that I'm unable to solve. Here it is. My main problem is that I don't know where to start. Any advice would be greatly appreciated. Also, if anybody knows of some web links that explain RC and complex DC currents and how to calculate voltage, current, etc... on them, I would appreciate that link. Here we go:
A singly charged heavy ion following a circular path in a uniform magnetic field of magnitude 0.053 T is observed to complete five revolutions in 1.58 ms. Calculate the mass of the ion.
Shouldn't the centripetal force equal the magnetic force, so:
qvB = ((m)(v)(v))/r
and then I could solve for m?
My problem is that I don't know what "singly charged heavy ion" means in terms of the charge. Does that give me the charge? There's no explanation of this term in the book.
Thanks for any help!
Hi, and welcome to PF.
qvB = ((m)(v)(v))/r
Yes.
There is some ambiguity there because it does not tell you whether the ion is positive or negative. In other words, it does not tell you whether the ion has lost an electron or gained an extra one. Nevertheless, you can still get the mass because only the magnitude of the charge is important for this question. That magnitude is the same as the magnitude of the charge on an electron:
1.6×10-19C.
Great! Thanks. I got it correct. This is what I did.
started with qvB = ((m)(v)(v))/r
simplified to qB = (mv)/r
solved for m = (qBr)/v
Figured that 5 revolutions in 1.58 ms was equal to 1 rev in 3.17e-4 sec
v, then was equal to (2(pi)r)/3.17e-4
substituted for v in the simplified equation, and did some algebra:
m = (qB(3.17e-4))/2(pi)
solved for m = 4.28e-25 kg
voila! Thanks for the help! I just needed a push in the right direction.
