How Does Potential Energy from Lightning Accelerate a Car?
  • Thread starter Thread starter alonzo
    Physics Urgent
The discussion centers on calculating the change in potential energy from a lightning strike and its effect on a car's acceleration. With a potential difference of 1.0 x 109 V and a charge of 30 C, the change in potential energy is calculated as 3.0 x 1010 J. This energy, when fully converted to kinetic energy, allows a 1000 kg car to achieve a final speed of 7746.15 m/s. The calculations utilize the formulas for potential energy (∆PE = q∆V) and kinetic energy (KE = 1/2mv2).
  • Understanding of potential difference and voltage
  • Knowledge of electric charge and its measurement in coulombs (C)
  • Familiarity with kinetic energy calculations
  • Basic algebra for solving equations
  • Study the relationship between electric potential and kinetic energy in physics
  • Learn about the principles of energy conservation in electric systems
  • Explore real-world applications of lightning energy conversion
  • Investigate the effects of electric fields on charged particles
This discussion is beneficial for physics students, educators, and anyone interested in the practical applications of electric potential and energy conversion in real-world scenarios.
alonzo
Please help me with this question! I understand the concepts of potential difference and charge etc but i don't understand what to do with the velocity.
1) In a lightning flash, the potential difference between the cloud and the ground is 1.0 x 10exp9 V and the quantity of charge transferred is 30 C. What is the change in potential energy of the transferred charge? if all of that energy could be used to accelerate a 1000 kg car from rest, what would be the car's final speed?
Thank you so much for your help!
The change in potential energy will be equal and opposite the change in kinetic energy of the charged particles (electrons). (Actually some of that goes into heating the air on the way down but I think you're expected to ignore that).
Just multiply the charge by the (initial) potential difference to find the energy.
Hello there,
I am sorry to hear that you are in distress and in need of urgent physics help. I will do my best to explain the concept of potential difference and how it relates to velocity.
Potential difference is a measure of the difference in electric potential between two points in an electric field. It is often referred to as voltage and is measured in volts (V). It is a crucial concept in understanding the flow of electric current.
In the case of a lightning flash, the potential difference between the cloud and the ground is 1.0 x 10^9 V. This means that there is a large difference in electric potential between the two points. The quantity of charge transferred, 30 C, is the amount of electric charge that moves from the cloud to the ground during the lightning strike.
To calculate the change in potential energy of the transferred charge, we can use the formula: ∆PE = q∆V, where ∆PE is the change in potential energy, q is the charge transferred, and ∆V is the potential difference.
Substituting the values given in the question, we get:
∆PE = (30 C)(1.0 x 10^9 V) = 3.0 x 10^10 J.
This means that the transferred charge has gained 3.0 x 10^10 joules of potential energy.
Now, to calculate the final speed of the car, we can use the formula for kinetic energy: KE = 1/2mv^2, where KE is the kinetic energy, m is the mass of the car, and v is the final velocity.
Since all of the potential energy gained by the transferred charge is used to accelerate the car, we can equate the two energies:
∆PE = KE
Substituting the values, we get:
3.0 x 10^10 J = 1/2(1000 kg)v^2
Solving for v, we get:
v = √(2(3.0 x 10^10 J)/1000 kg) = 7746.15 m/s.
Therefore, the final speed of the car would be 7746.15 m/s.
I hope this helps you understand the concept of potential difference and how it relates to velocity. If you have any further questions, please don't hesitate to ask. Best of luck with your studies!
19K
