Is the concept of attractive and repelling fields a reliable law of physics?
  • Context: Undergrad
  • Thread starter Thread starter TheRealTL
    Law Physics
The discussion centers around the reliability of the concept of attractive and repelling fields as a law of physics. Participants explore theoretical implications, contextual applications, and the philosophical underpinnings of such a concept, with references to various physical phenomena.
  • Meta-discussion
  • Some participants argue that the question is poorly defined and lacks context, making it difficult to answer definitively.
  • One participant questions the empirical content of the concept, suggesting it does not predict observable phenomena, thus cannot be considered a law of physics.
  • Another participant raises the issue of the electrostatic force between a point charge and a neutral metallic object, questioning whether it is always attractive.
  • Some participants propose that all physical systems are defined by their possible states and observables, suggesting that ratios of dimensionful observables could relate to attractive and repelling forces.
  • There is a discussion about the implications of gravitational fields, with some asserting that in orbital mechanics, only attractive fields are at play.
  • One participant introduces the idea that the language of attraction and repulsion may be too restrictive to encompass all physical laws, citing examples like the bending of starlight.
  • Another participant suggests that if the concept were true, it could unify gravity and dark energy, although this remains speculative.
  • Some participants express skepticism about the utility of the proposed concept, comparing it to overly simplistic models in other fields.
Participants do not reach a consensus on the validity of the concept as a law of physics. Multiple competing views are presented, with some rejecting the idea outright while others explore its implications and potential applications.
The discussion highlights limitations in the definitions and assumptions surrounding the concept of attractive and repelling fields, as well as the challenges in applying it to various physical scenarios.
TheRealTL
Let's go old school thought experiment.
If you say no, state the real world exception.
If you say yes, state the consequences of it not being a law.
All known systems are observed as the ratio of attractive and repelling fields
It is difficult to answer "yes" or "no" to such a poorly defined question. We do not have much of a context. So let us go old school and you illustrate for us how your formalism deals with a simple falling ball in a uniform gravitational field. Where is your "ratio of fields" in this context for instance ?
Is the electrostatic force between a point charge and a neutral metallic object always attractive? Michael Levin, Steven G. Johnson http://arxiv.org/abs/1007.2175
No.
You ask "Is this a law of physics?"
To be a law of physics, in the traditional sense, a statement must predict some observable phenomena, so that it can be empirically tested.
This statement of yours does not appear to predict anything that one could observe.
In which case it has no empirical content, and therefore cannot be a law of physics.
I suppose the right venue for your idea might be a branch of philosophy. Metaphysics?
The Philosophy of Physics?
The publishing house called North Holland has a book out called Handbook of Philosophy of Physics. I've read one of the chapters, by George Ellis, which was pretty good. You might like this Handbook of PoP.
Maybe you could get your thread transferred to Philosophy forum, or to General Physics, where people could discuss it.
They would probably say that on a metaphysical level your idea is naive or simply wrong, because many if not most physical theories/models do not use the ratio of directional fields to explain/predict. I say "directional" because you qualify your fields idea as "attractive or repelling". Ratios are not always well-defined. May require simplifying assumptions. With enough simplifying assumptions you may be able to cram many physical models into some pre-conceived mold, but then by over-simplifying you lose the ability to make accurate predictions.
I think the OP needs further explanation.
I think that all physical systems are defined by their possible states and their observables.
On the other hand if an "observable" is dimensionful then such an observable is only a quantity (i.e. an actual number) when measured in some units. But since units are not a part of the physical system without themselves being observables it is only really true that "real observables"( for which we can assign some quantity) can be ratios of dimensionful observables.
Further more I think that in general observables must be accelerations or reaction rates both of which care dimensionful i.e. 1/time. So really only ratio's ok these observables are quantities that are observed in the sense above.
Then it seems to make sense the repulsive/attractive can be understood as acceleration/declaration.
me too.
as written, without explanation, NO..
The set of all real numbers.
Then again I have no idea,whatsoever, what old school means.
Is this a law of physics? No. It's a metaphysics conjecture, and a bad/naive one.
A photon is approaching a galaxy. It does not accelerate (as if experiencing a force.) What happens is its wavelength gets shorter.
The language of accel/decel, or of attract/repel is too restrictive to cram all physics laws into that particular format.
Moreover the Newton force picture depends on having a fixed geomtric setup. What about the bending of starlight observed by Eddington in 1919. Does it really work to put it into an attractive force paradigm?
A prescriptive metaphysics can be a straight-jacket. Doesn't Philosophy of Physics (PoP) and studying the language/formulation of physical law belongs in general phys. or in philosophy?
To clarify, this is the kind of answer I'm looking for. To keep the discussion going, I would suggest that a falling ball eventually comes to a sudden stop. Implying the electric field represents a repelling force.
What about two bodies in orbit with each other?
There is only an attractive field at work there.
Well to begin with the electric field didn't disappear. And the orbit didn't get created by nothing. I would also like to point out you need to remember what keeps the system from exploding/evaporating or collapsing into a singularity.
What if gravity was the only force in a system?
How would you use your hypothetical law in an application?
I can also say that a ripe banana is yellow. It is not debatable, but it doesn't really go anywhere either.
You have a statement that might be debatable, but how is it useful?
I think you miss the point. I think the question is more about what we can measure directly in a scientific manner (so we don't include "seeing the photon is red" or anything like that). When we make a measurement we get data consisting of numbers and angles. My interpretation( which may be wrong) of the OP is that this data corresponds to ratios of attractive and repulsive forces.
In the case of light bending clearly this can be understood as an attractive force. Clearly gravity is an attractive force.
Well for me personally I ask what if the universe is a measurable system. Under the standard model gravity is considered an attractive force but has no repelling equivalent.
If this law is true, then dark energy in my opinion, could be unified with gravity. If of course this is a true law of physics.
P.S. If I know the banana is yellow. I eat it. It does go somewhere.
@OP:
This is a pointless discussion. Using opposite word to describe phenomenon lead to nowhere. This is very similar to the theological explanations:
-Yesterday was a sunny day because God was happy. Today is raining because He is angry.
Such simplified models can explain anything - but I don't believe in them.
You can call it a science - in fact, chemists do.
Has anyone noticed how lousy are some chemistry textbooks? Everything is on the line of "electrons bond atoms. Except when they don't" or "Octet is the most stable configuration. Except when it isn't". I don't like most chemistry textbooks for this reason. I do like chemistry, though.
  • · Replies 190 ·
18K
  • · Replies 37 ·
  • · Replies 49 ·
