Calculating Limits: Understanding Lim 1 - cos(x)/x^2 x->0
  • Thread starter Thread starter Halcyon99
    Limit
The discussion revolves around calculating the limit of the expression (1 - cos(x))/x^2 as x approaches 0. Participants are exploring the behavior of this limit and referencing known limits and mathematical rules.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to evaluate the limit using different methods, including L'Hôpital's Rule and series expansion. Questions arise regarding the correct interpretation of the limit and the potential for confusion with calculator outputs.
There are multiple interpretations of the limit's value, with some participants suggesting it approaches 1/2 while others express uncertainty about their calculations. Guidance has been offered regarding the use of calculators and the importance of ensuring they are set to the correct mode.
Some participants note the potential for confusion due to the use of degrees versus radians in calculators, which may affect the results. There is also mention of needing to convert the expression into a known limit form for evaluation.
Halcyon99
Lim 1 - cos(x)/x^2
x->0
My attempt:
lim [1 - cos (x)/ x][lim 1/x] = (1)(1/0) :cry:
Please help me with some basic examples.
lim [1 - cos (x)/ x]=1?
How ??
While solving limit Problems, you make use of certain solutions
like
[tex]\lim_{x\rightarrow 0} \frac{Sin(x)}{x}=1[/tex]
[tex]\lim_{x\rightarrow 0} \frac{e^x-1}{x}=1[/tex]
eg:[tex]\lim_{x\rightarrow 0} \frac{Tan(x)}{x}[/tex]
=>[tex]\lim_{x\rightarrow 0} \frac{\frac{Sin(x)}{cosx}}{x}[/tex]
==>[tex]\lim_{x\rightarrow 0} \frac{Sin(x)}{x} \lim_{x\rightarrow 0} \frac{1}{Cosx}[/tex]
==>1*1=1
end example==================
In this case,try to convert this into a known limit
HINT:[tex]cos2x=1-2sin^2x[/tex]
use le'hopitals(spelling?) rule
Hmm, I got 1/2. I think you left the x^2 out of the original denominator:
lim x-->0 of ( 1-cos(x) )/x^2
= lim x-->0 ( sin(x) )/2x
= lim x-->0 ( cos(x) )/2 = 1/2
BTW, here's a good page on L'Hopital's Rule:
http://www.math.hmc.edu/calculus/tutorials/lhopital/
PS -- I went back and used a calculator to plug in small numbers for x, and it looks more like the limit of the original function of x goes to zero. I wonder if I did the first differentiation wrong, or the calculator is fooling me. What do other folks get?
Answer
I guess this can be solved in eitherof following 2 ways.:
1. Using formula of cosx=1-(x^2)/2!+(x^4)/4!...
so that
(1-cosx)=x^/2-(x^4)/4!...
=x^2[1-(x^2)/4!...]
so that
Lt x->0 of (1-cosx)/x^2 becomes :
=Lt x->0 of 1/2[1-(x^2)/4!...]
=1/2
2. other method could be usin L'Hospital's rule using differentiation
this too yields answer as 1/2
take care :smile:
Your calculator was probably using degrees instead of radians.
Perfect! Thanks, Muzza. I thought I was losing my mind!
I was going to suggest to Halcyon99 that a good way to check the results you get from L'Hospital's Rule is to just plug some small numbers into the original fractional expression using a calculator. Now I know to add the caveat that the calculator needs to be in Radian mode. I'd spaced the part about when series expansions or other expressions are shown sharing a variable between trig functions and algebraic functions, the trig function arguments are in radians.
Thanks again, -Mike-
  • · Replies 29 ·
