Thread Closed
Bethe-Bloch : energy loss to a single electron?
Share Thread Thread Tools
Aug24-10, 07:47 AM   #1
Hi guys,
the Bethe bloch (BB) equation, in combination with the material density, gives the energy deposited in the material per unit path length. One of the terms in the BB equation is the maximum energy transferred to an electron by the incident particle. So i am assuming, the energy loss calculated by the BB equation, is assumed to be transferred to a single electron and not numerous electrons? If the energy is transferred to a single electron, then this electron will cause further ionization, at a rate of one electron every 3.65 eV for Silicon.
For example, a minimally ionizing particle will deposit 3.8 MeV per cm, or 380 eV per micron in Silicon. Does this mean a minimally ionizing particle will transfer 3.8 MeV to a single electron in 1 cm of Si, then this electron will cause further ionization? Similarly, if i was working in microns, does this mean that on average 380 eV will be transferred to a single electron per micron in silicon? I know atom spacing’s are approximately in the Angstroms range. For the most accurate calculation of the energy transferred to a single electron, should dEdX be calculated every Angstrom, as opposed to every micron or cm ? Is this not done due to increased processing times for computers?
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Aug24-10, 11:59 AM   #2
The Bethe-Bloch equation is discussed in depth in Section 27.2 of
http://pdg.ihep.su/2009/reviews/rpp2...les-matter.pdf
The incident ionizing particle "collides" with many electrons in the silicon during its passage through matter. Because the mass m of recoil atomic electrons is so light, the momentum transfer is very small; p2 = 2mErecoil where Erecoil = ½mv2. The Bethe-Bloch equation Eq. 27.3, plotted in Fig. 27.2, is derived using the well-known Coulomb-scattering equations of the incident ionizing particle on the atomic electrons. The energy loss distribution of the recoiling electrons is based on the impact parameter (distance of closest approach) of the incident particle and atomic electron, and is best discussed in books like Ritson " Techniques of High Energy Physics" (Interscience) pages 11-24**. The "I" in the denominator of the Bethe Bloch equation is the mean ionization energy, or mean energy transferred from the incident ionizing particle to the recoil atomic electron in a single collision. Infrequently, the collision transfers a large energy to the recoil electron, this is called a delta ray. See Section 2.2.5 in above pdf. The recoil electrons in turn create ionization and subsequent conduction electrons (or holes) in semiconductor (germanium or silicon) depletion regions.
[added] **See also chapter 13 in Jackson Classical Electrodynamics (2nd edition) or
http://www.google.com/url?sa=t&sourc...7l6-1ZsL8iN58w
Bob S
Thread Closed
Tags
bethe-bloch, electron
Thread Tools
Similar Threads for: Bethe-Bloch : energy loss to a single electron?
Thread Forum Replies
Bethe-Bloch equation for high-energy muons High Energy, Nuclear, Particle Physics 10
Bethe Bloch formula High Energy, Nuclear, Particle Physics 1
obtaining range from bethe-bloch formula High Energy, Nuclear, Particle Physics 2
Bethe-Bloch Equation different materials High Energy, Nuclear, Particle Physics 9
Obtaining the CDSA range of Bethe-Bloch Equation High Energy, Nuclear, Particle Physics 0
