The discussion revolves around the chemical behavior of a mixture of pure nitric acid and pure hydrochloric acid, specifically addressing the presence of H2NO3(+) and ClO4(-) ions in the mixture. The scope includes theoretical explanations and chemical reasoning related to acid strength and protonation.
- Technical explanation, Conceptual clarification, Debate/contested
- Some participants propose that HClO4 is a stronger acid than HNO3, leading to the protonation of HNO3 by HClO4.
- Others argue that the basicity of the oxygens in HNO3 allows it to behave as a base towards the stronger acid, HClO4.
- A participant suggests that the greater electronegativity of chlorine compared to nitrogen may contribute to the observed behavior of the acids.
- One reply emphasizes considering the stronger conjugate acid-base pair in the overall reaction.
Participants express differing views on the reasons behind the behavior of the acids, particularly regarding the basicity of HNO3 and the influence of electronegativity. No consensus is reached on the explanations provided.
The discussion does not resolve the underlying assumptions about acid strength and basicity, nor does it clarify the specific conditions under which the reactions occur.
