Kepler's Third Law orbiting planet
The discussion revolves around the interpretation of Kepler's Third Law in the context of planetary orbits, specifically addressing the meaning of the semi-major axis $a$ in relation to the distances involved in a two-body system. Participants explore the implications of including multiple planets and the assumptions underlying the law's applicability.
  • One participant questions whether $a$ refers to the distance from the planet to the star or the distance to the center of mass, suggesting it is the former.
  • Another participant clarifies that the semi-major axis is defined as the length of the longer radius of an orbit.
  • A different participant emphasizes the importance of the frame of reference in understanding the definition of the semi-major axis.
  • One participant notes that Kepler's laws apply only to two-body systems and are valid primarily for planets of negligible mass, while another challenges this by stating that Kepler's laws do not impose restrictions on mass, arguing that they are valid as long as the bodies can be treated as point particles.
  • Another participant discusses the derivation of the equation, stating that $a$ represents the semi-major axis of the ellipse formed by the motion of the two bodies around their center of mass.
  • Several participants engage in a debate about the assumptions made in the derivation of Kepler's laws, particularly regarding the mass of the planets and the validity of the laws in multi-body systems.
Participants express differing views on the interpretation of $a$ and the applicability of Kepler's laws, particularly regarding the significance of planetary mass and the conditions under which the laws hold true. There is no consensus on these points, and the discussion remains unresolved.
Limitations include the dependence on the assumption of negligible mass for planets in the context of Kepler's laws and the implications of introducing additional bodies into the system, which complicates the application of the laws.
natski
Dear all,
A very simple (almost embarrassingly so) question here, but I just want to double-double check what is going on.
Kepler's Third Law states for a planet of mass Mp orbitting star of mass M* at a semi-major axis $a$ with a period P, that:
[P/(2pi)]^2 = a^3/G (Mp+M*)
Now what I want to know is what is $a$ referring to? Is it the planet to star distance (assuming a circular orbit) or the planet to centre-of-mass distance? I think it is the former.
What if we have a second planet as well and assume perfect Keplerian orbits for the two planets... now if $a$ really does correspond to the planet-star separation then then this must be a variable since the star-barycentre distance is now changing as a result of the presence of the second planet.
Can anyone clear this up?
Natski
Astronomy news on Phys.org
I think maybe you misunderstood my question. I am speaking of which frame of reference that definition is valid.
You two are talking past one another. Natski, you are not speak of the frame of reference. Length is an invariant in Newtonian mechanics. It doesn't vary from one frame to another.
Kepler's laws apply only to planets of negligible mass, and only to two body systems. Make the mass of the planet significant (e.g., Jupiter) and Kepler's laws are not correct. Throw in other planets with non-negligible mass and the assumption of elliptical orbits is not correct.
natski said:
Dear all,
Natski
With the equation:
[tex]\left(\frac{P}{2 \pi}\right)^2= \frac{a^3}{G(M_p+M_*}[/tex]
"a" is the sum of the semi-major axes of the two bodies' orbits, which would be the distance between them in the case of an circular orbit.
Another way of thinking about what 'a' is would be to go back to the derivation of the equation. In setting up the appropriate equation of motion (with the center of mass coincident with the origin of coordinates), you use a position vector with a length that is equal to the separation between the two masses. The solution yields that the evolution of this vector sweeps out an ellipse. Thus 'a' is the semi-major axis of this ellipse. Careful substitutions show that the masses also sweep out ellipses about the center of mass, however, with different major axes than the first ellipse.
I don't see how the first part (...planets of negligible mass) of this statement is correct. Neglecting relativity, Kepler's laws make no restriction on the masses of the bodies. Indeed, mass terms show up in the equations. Remembering that these laws follow from Newton's Law of Universal Gravitation, the only assumption the is made is that the bodies are point particles. Considering the great distances between planets relative to their diameters, this assumption is valid.
I do, however, agree with the statement that Kepler's laws only apply to two-body systems. However, the gigantic mass of our sun makes Kepler's laws approximately valid for most of the planets in our solar system (i.e. the (n>2)-body effects are negligible and you can get away with only consider the sun-planet interaction).
Sure it does. Kepler's third law is that P2∝[/size]a3. Newton's laws on the other hand tell us that P2=a3(2π)^2/(GMp+GM). Kepler's third law would dictate that the right-hand side of this latter equation is constant.
The derivation from Newton's laws also assumes the planets are of negligible mass.
The second equation is commonly called Kepler's third law (whether or not he actually wrote it done precisely) because it implies the first equation. For elliptical orbits, given three of the variable quantities, you are able to determine the fourth. Even if you did not know the masses of the two bodies, you can still deduce how much the period must change for a given change in the semi-major axis or vice-versa.
Again, this is never invoked. Mass plays a central role in Newton's laws.
9K
