Physics-12th grade-forces and friction PLEASE HELP ME
  • Thread starter Thread starter KatieM
    Friction
The problem involves calculating the mass of a person based on the force of kinetic friction experienced while sliding on a waxed floor. The context is set around a scenario involving forces and friction, specifically focusing on the coefficient of friction and the relationship between force, mass, and weight.
  • Participants discuss the formula for kinetic friction and the relationship between normal force and weight. Questions arise regarding the interpretation of variables and the distinction between forces in Newtons and mass in kilograms.
Participants have engaged in clarifying the relationships between the variables involved, with some guidance provided on the formulas. There is an ongoing exploration of how to correctly apply the concepts of weight and mass, with multiple interpretations being discussed.
There is a mention of uncertainty regarding which numbers to use in the formulas, as well as a need for clarification on the definitions of the variables involved. The discussion reflects a typical homework scenario where assumptions and definitions are being questioned.
KatieM
physics-12th grade-forces and friction PLEASE HELP ME!
I'm not really sure about how to go about this problem. It says:
After every full moon, Mr. Sowell likes to slide around the hallways on freshly waxed floors in his socks. If the U* between the socks and the floor is 0.120 and amount of force required to move him 102 N, what was his mass in kg.
If i just knew which formula to use, and what each thing stood for I'm pretty sure i'd be able to solve this. the U* that i wrote is the funny looking greek U calle mue or whatever. Please help me someone!
Here's a hint: the force of kinetic friction is [itex]F_f = \mu N[/itex], where N is the normal force pushing the surfaces together (the sock and the waxed floor). The normal force is equal to the man's weight. Apply what you know (or should know!) about weight and mass, and what's given in this problem.
thank you for the help...I just wasn't sure what numbers to plug in where... :smile:
i still have a question though... i thought i understood it but i guess not
if i use the formula Ff=u*Fn
then which variables stand for Newtons and kg's
Forces are in Newtons and masses are in kg. The formula I gave just has forces. What's the formula that tells you the weight of given mass?
so i would rearrange the formula and get Fn=Ff
U*
and 102N
.120 = 850kg
is that right?
You rearranged the formula correctly, but you are interpreting it incorrectly. You solved for the Normal force [itex]F_n = F_f/\mu = 850[/itex]. That's the normal force, 850 Newtons, not kg. But, as I told you earlier, the normal force equals the man's weight. So what's the relationship between weight and mass? (Look in your book!) In other words, what is the mass of someone who weighs 850 N?
okay...i think i got this now...Mass=force/acceleration so 850N/9.8m/s^2=86.7 kgs
Excellent.
It's good to remember that the weight of a mass (on the Earth's surface, that is) is given by w = mg.
thank you for your help :) i should be able to do the rest of my worksheet now
10K
19K
