Can Motion Exist Without Force?
  • Thread starter Thread starter r-soy
The discussion revolves around the concept of motion and force, specifically whether motion can exist without an external force acting on an object. Participants are examining statements related to Newton's laws of motion and their implications.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are questioning the validity of true/false statements regarding motion and force, with some seeking clarification on the reasoning behind the answers. There is a focus on the logical structure of the statements and the definitions of motion and acceleration.
Some participants have provided feedback on the correctness of the original poster's answers, indicating a mix of agreement and disagreement. There is an ongoing exploration of the reasoning behind each statement, with suggestions for clearer explanations and logical consistency.
Participants note that the original poster's justifications for their answers may not align logically with the statements provided. There is an emphasis on understanding the distinction between velocity and acceleration, as well as the implications of Newton's laws.
r-soy
True or false :
It is possible to have motion in the absence of a force (F)
beacuse no motion without force
If an object is not moving , no external force acts on it (T)
beacuse each object will not move unless a force acts on it
If a single force acts on an object , the object accelerates ( T)
beacuse every object has force has accelerates
If an object experiences an acceleration , a force acts on it ( T)
If an object experences no acceleration , no external force acts on it ( T)
beacuse every object has no force has no accelerates
If the net force acting on an object is in the x direction the object moves in the x direction ( T )
beacuse when force effet on the object will go same direction of force
I want check my answer please >>
By my count you have 2/6 correct, 4/6 wrong. Think about the difference between velocity and acceleration.
It would be much easier to help if you explained your reasoning.
I explained my reasoning by apply Newton second law
Why don't you explain what you think motion means? The term appears in a number of problems that you got wrong, so you might want to be more specific about things.
I get the similar count as phyzguy. Try explaning the reasoning to each prob .. exactly why you chose whether true or false.
r-soy said:
Do you not know what "explain" and "reason" mean?
r-soy said:
True or false :
I can't imagine how you would answer these "true" or "false". Many of them simply don't make sense.
The 'because' seems to contradict the statement!
Again, a non-sequitur. "because each object will not move unless a force acts on it" would explain "if an object is moving there must be an external force acting on it", not the statement given.
Okay- not very good English, but true.
Once again a "p implies q because q implies p" statement. Not logical.
The statement is true but because of "every object that has a force accelerates" not the reason given here.
[qote]If the net force acting on an object is in the x direction the object moves in the x direction ( T )
beacuse when force effet on the object will go same direction of force [/quote]
True
Most of these seem to be of the form "if p then q because if q then p" (which is false logic). Also, as others have tried to point out, an object can move in a straight line, at constant speed, with NO force on it. You don't seem to realize that.
but all my answer are correct ??
Halls, I assumed that the "because ..." following each question was his/her attempt at justifying the answer (T/F) that he/she gave for the statement above that line. If that's the case, then the questions make sense, it's just that the OP's explanations don't.
Most of your answer are not correct if you've correctly transcribed each statement.
  • · Replies 41 ·
  • · Replies 75 ·
  • · Replies 37 ·
