What Are the Color Codes Used in Computers for Outputting Videos?
The discussion revolves around the color coding used in computers for outputting videos, focusing on how colors are represented digitally and the processes involved in converting analog signals to digital formats. Participants explore various aspects of color representation, data compression, and the technology behind video output.
  • One participant inquires about the specific color codes used in video files and how these colors are represented digitally on screens.
  • Another participant explains that colors are typically represented as a combination of three primary colors (red, green, blue) with intensity values digitized for each pixel.
  • It is noted that colors can be described using a 32-bit format, with 8 bits allocated for each color component and an additional alpha channel for transparency.
  • Discussion includes the mention of data compression techniques that reduce the amount of data needed for video output, despite the high pixel count in modern resolutions.
  • Some participants discuss the existence of various color depths, such as 24-bit, 30-bit, and 48-bit color, and their applications in different contexts, including PC gaming and digital cinema.
  • A question is raised about the conversion process from analog to digital signals, specifically regarding the existence of analog-to-digital converter programs and their functionality.
  • Another participant confirms that modern devices convert analog light signals into digital formats, while older technologies primarily used analog methods without digital conversion.
  • Historical context is provided regarding older analog devices and their limitations in terms of digital capabilities.
Participants express a range of views on the specifics of color representation and the technology involved in video output. There is no clear consensus on all aspects discussed, particularly regarding the details of analog-to-digital conversion and the various color depths.
Some limitations in the discussion include assumptions about the audience's familiarity with technical terms and concepts, as well as the varying levels of detail provided regarding different color models and conversion processes.
This discussion may be useful for individuals interested in digital video technology, color representation in computing, and the technical aspects of video output and conversion processes.
challarao
Hi!
I am so fascinating about the computers and digital technology...
If we consider a number or a letter they have specific digital codes and compilers convert them into numbers or letters for humans...
In computers each and every signal is digitalized,in that case videos are also digitalized..
I've been puzzling how they are coded,suppose in a video file a person wears a red shirt and he has white skin..then in order to output the signal to the monitor...are there any colour codes in computers to send output...?
SOrry for any mistakes I made..
Please explain me if you know these aspects...
Any help or suggestion or weblink highly appreciated...
Thanxxx..waiting for replies
Computer science news on Phys.org
I can't quite understand your question. However colors are coded by describing them as the sum of three primaries (blue, green, and red). For each primary the intensity is then digitized and these three numbers describe the color at each pixel of the image.
The above is the basic description for a bitmap code. In practice there are methods to condense the data, using correlation between neighboring pixels.
Colors are generally described with a set of 32 bits segmented into 8 bits per color component Red, Green, Blue and Alpha.
So for every dot on your screen there is a code like:
11111111000000001111111100000000
A blu-ray sized movie with a 1920x1080 resolution will have 2,073,600 pixels. At 32 bits each that is 66,355,200. At 24 frames per second that is 1536 Megabits per second.
However, Bluray players only operate up to about 40 Megabits per second for video.
Luckily, a good deal of the data we see on our screen is redundant. The way they can cram all of that information into such a small stream (Nearly 40x smaller than the raw format) is through data compression algorithms that take advantage of certain kinds of redundancy in the images and video they compress.
Cool, I have never had this explained to me before. Interesting to know.
I didn't understand your reply!
what is "54 68 65 20 61 74 68 65 69 73 74 73 20 72 69 6f 74 65 64 20 61 66 74 65 72 20 74 68 65 20 44 75 74 63 68 20 70 75 62 6c 69 73 68 65 64 20 61 20 62 6c 61 6e 6b 20 63 61 72 74 6f 6f 6e 2e
ΘΤ "
Alpha is a transparency value used when combining multiple images (how much of one image shows through another):
24 bit RGB color uses 8 bits per color as mentioned, and is the most common method used on PC's.
Many PC video cards also support 30 bit RGB color at 10 bits per color, but with a limited selection of resolutions, and generally digital monitors don't support 10 bits per color (just CRT and some digital projectors). Few PC games support 30 bit color, one that I remember was Tomb Raider - Angel of Darkness made back in 2003.
36 bit color is used in digital cinema, but I'm not sure if that's RGB.
48 bit RGB color, at 16 bits per color is supported on some graphic workstations.
http://en.wikipedia.org/wiki/RGB_color_model
http://en.wikipedia.org/wiki/Digital_cinema
Thanks for replies
A small tag question
If digital signals of a video are transferring through one computer to another computer the second computer can decode the signals and process them.But when this transfer is between analogous and digital how can computer convert them.Is there any decoding of voltage differences from analogous circuits.
Especially I am asking about analogous to digital converter programs..are they exist.?
challarao said:
analog to digital converter programs..are they exist.?
Yes, most modern cameras, camcorders, and video capture devices in genernal, convert light into some type of digital format, using various types of components that convert the analog intensity of light for each color into some number of bits of data per color.
Older camcorders (Betacam, Betamax, VHS, Hi-8) converted the analog inputs into analog signals on a magnetic tape, without a conversion into a digital format. Fully analog TV's also converted received analog signals into analog levels of brightness for each color for display. The only digital aspects to these devices were the timings for sweep rates and refresh rates.
There were also analog computers around 40 to 50 years ago that could solve simple feedback type differential equations using components that could integrate in addition to being able to add, subtract, multiply, divide voltage levels. These were typically range limited to +/- 100 volts and only accurate to about .1 volt.
10K
  • Sticky
9K
