RLC circuit - total impedance,phasor analysis etc
The discussion revolves around an RLC circuit consisting of a resistor, inductor, and capacitor connected in series across an AC source. Participants are tasked with calculating total impedance, current, voltage drops across components, phase angles, and resonant frequency, as well as drawing a phasor diagram.
  • Mixed
  • Participants explore calculations for total impedance and current, questioning the need for maximum voltage in certain formulas.
  • There are discussions about the phasor diagram and how to account for phase differences in voltage drops across components.
  • Some participants express confusion about finding resonant frequency and the quality factor of the circuit.
  • Questions arise regarding the correctness of numerical answers and the necessity of drawing diagrams.
Participants have shared various attempts at calculations and are actively engaging with each other's reasoning. Some have provided guidance on using phasor diagrams and the relationships between voltage and current. There is a recognition of the need to clarify certain concepts, but no explicit consensus has been reached on the final answers.
Participants mention constraints such as reliance on given values and formulas from textbooks, as well as uncertainties about the implications of using maximum voltage versus RMS voltage. There is also a discussion about the need for clarity on phase angles and the conditions for maximum current flow.
pat666
A resistor, R = 100 Ω, an inductor, L = 0.20 H and a capacitor, C = 3 µF are connected in series across an ac source of VS = 100 V and frequency, f = 200 Hz. Calculate the following for this series circuit:
a) the total circuit impedance (Zt)
b) the total circuit current (IS)
c) the voltage drop across each component (VR, VL and VC)
d) the phase angle between VS and It.
e) Draw the phasor diagram of voltages and current for the circuit.
f) What is the frequency of the ac source for maximum current to flow?
g) What is the quality factor, Q, of the circuit at the frequency calculated in part f)?
in attachment
a) I think is right.
b) Not sure about since i don't have vmax do I??
c) really doubt is right but I can't think of another way to do it
d) tan(phi)=X_L-X_C/R which I got -7.9 degrees?
e) I'm trying to understand the phasor analysis paragraph in the text and all I know is that I will need VR,max,[tex]\epsilon[/tex]max and VC,max all of which I should be able to calculate when I know if my I from b) is right.. even when I have that I am still not sure how to draw it?
f) and g) I am really stumped on...
Thanks for any and all help.
the d) I have in the pic is for another question-sorry I can't see how to remove that attachment.
Assume the AC voltage is 100 V RMS. Vmax is V RMS/.707. But I am not sure why you need Vmax here. Use: I = V/Z
The phasor sum of all the voltage drops adds (vectorally) to the applied voltage. Remember that voltage across the inductor is 180 degrees ahead of the voltage across the capacitor and the voltage across the resistor is perpendicular to that across the inductor and capacitor. So draw VR pointing along the +x axis, VL along the + y-axis and VC along the -y axis. VR = IR. |VC| = IXC and |VL|= IXL
Looks right.
You don't actually need to use Vmax. Just use the given 100 VAC (rms) and add them using a phasor diagram. AM
Thanks Andrew,
for b I get the same answer, the reason I had Vmax is because the formula in my textbook says I = Vmax/Z but that's probably for Imax?
Still confused about c) do I need to draw a diagram? I used VR = IR. |VC| = IXC and |VL|= IXL so my numerical answers should be right?
e) I am still stumped on, how do i find the angle for V r max,E max,Vcmax or the magnitude?
f) not sure--thinking that I should find I_max using Irms/swrt(2) but that will give me the max current flow at 200Hz won't it?? If I am looking for max current flow I'm after the resonant frequency i think but I don't know any formula for that??
g)Q=X_L/R=wL/R but since I don't know how to find the frequency I can't do this yet??
pat666 said:
Thanks Andrew,
That would be Imax, correct.
Right. But according to Kirchoff's laws, the voltages must add up to the applied voltage. They do add up at any given moment but to do that you have to take into account the phase differences between the voltages. To do that, you use a phasor diagram.
Draw a phasor diagram of the voltages. You don't need to use Vmax. You can use Vrms. Draw the voltage vectors as I suggested in my last post using the values you found in c). Then draw a phasor showing the current vectors. The lengths will be proportional to voltages but the phase angles of the inductor and capacitor currents will have different directions.
Use I = V/Z. In order to maximize I, you need to minimize Z. How do you do that? (hint: express XL and XC in terms of f, L and C.)
Find f and you will have no problem.
AM
Hey Andrew,
been a while but I finally got around to finishing this problem.
I'm really not sure about my phasor diagram, I ended up using Vmax just because I had it worked out from a previous question. my Vcmax is way bigger than both my V_r,max and emf max - not sure if this means its wrong or not?
for f) I got 205.5Hz and for g I got 2.58, sound right? also what are the units for quality factor?
Thanks
  • · Replies 21 ·
