Quick question - has length contraction actually been experimentally confirmed?
The discussion revolves around the experimental confirmation of length contraction, a concept in the theory of relativity. Participants explore whether length contraction has been observed in practice, particularly in the context of particle accelerators, and examine the implications of such observations.
  • Some participants note that time dilation has been experimentally confirmed, but question the experimental evidence for length contraction.
  • One participant claims that the bunch length in particle accelerators demonstrates length contraction, although this view is not universally accepted as definitive evidence.
  • Another participant seeks clarification on how bunch length relates to length contraction and its implications for particle packing in accelerators.
  • There is a discussion about whether the contraction of electrostatic fields allows particles to bunch closer together at high velocities.
  • Some participants argue that all lengths, including those of electrostatic fields, contract in a relativistic frame, while others question the physical implications of this contraction.
  • A participant introduces a thought experiment involving rods in a circular accelerator, suggesting that if they were moving fast enough, they could fit more than expected, but this is challenged as not being a valid demonstration of length contraction.
  • Another participant mentions that direct experimental verification of length contraction is not possible with current technology, suggesting that only indirect verification exists.
Participants express differing views on the experimental confirmation of length contraction, with some supporting its demonstration in particle accelerators while others remain skeptical. The discussion includes multiple competing interpretations and remains unresolved regarding the physical implications of length contraction.
Participants highlight the complexity of interpreting length contraction, including discussions on causality and the nature of relativistic effects. There are references to the Ehrenfest paradox and the limitations of current experimental technology in verifying length contraction directly.
jeebs
Hi,
I am aware that time dilation has been observed experimentally with atomic clocks on satellites etc. but after a few google searches I have not found anything about experimental confirmation of length contraction. Has this been observed at all? If so, how was it tested?
thanks.
I would say that the bunch length has been demonstrated to contract in particle accelerators (otherwise they would not work as expected). But I know that is not universally accepted as a demonstration of length contraction.
Hi DaleSpam Could you provide a simple conceptual explanation of bunch length and how it demonstrates contraction. I have sought this before and researched the web but find myself still unsure of the concepts. If what I remember is correct it relates to implse timing for acceleration but I couldn't really grasp the connection to contraction.
Thanks
In a particle accelerator you don't accelerate an individual particle, you accelerate a whole bunch of particles. Each of the particles in the bunch has the same charge, so they repel electromagnetically quite strongly, and one of the things that you have to do in designing an accelerator experiment is figure out how densely you can pack them given the limitations of your equipment. This is often done in the rest frame of the bunch where the repulsive interactions are easier to calculate. If you do not consider length contraction then you get the wrong answer about how many particles you can pack into the bunch.
Does this then mean what is being contracted is the electrostatic field associated with the electron
so they can acutally bunch closer together than would be possible at low velocities?
Thanks for keeping it simple :-)
Yes. Similarly (in principle) with a solid material, the intermolecular EM fields contract so the rod is shorter.
Hold on there pardner , what happened to "contraction is purely kinematic , it does not make sense to talk obout real or not ...or to look for causality or physical implications with the Lorentz effects" QUotes here being generic, not referring to you specifically [at least maybe not]? :-)
Thanks
There's a frame that is moving relativistically relative to us. Everything in that frame is length-contracted, yes, even the electrostatic field.
I wasn't making any distinction between electrostatic fields and other contraction , only making a comment, partially a joke , related to the fact that DaleSpam made contraction sound pretty darn physical and causal. I.e. Things contract because the EM fields contract.
I don't understand the point you are trying to make. What is surprising to you here? All lengths contract, regardless of whether the length is the length of a rod or some characteristic EM field.
What if we had some sort of accelerator device in a lab of radius r meters, and some rods with rest lengths of Pi meters each and what if we could comfortably fit more than 2*r rods around the perimeter if they were moving at high enough velocity. Would that be physically real enough for you?
I'm relatively new to relativity at this depth, but I was wondering why the EM fields contract due to relativistic effects. Obviously it's not because the values of [\mu]0 or [\epsilon]0 have varied, otherwise the frame wouldn't be a reference frame, correct?
Thanks for any information.
Sorry DaleSpam I should probably not indulge in my ideosyncratic humor.
There was absoutely nothing I found surprising and I appreciated your clear and direct explication which made perfect sense to me.
The basis of my comment , not exactly a point, was the inconsistency between two interpretations of the Lorentz effects.
There are many threads where people ask about the causal mechanism of these effects and whether they are to be taken as real or not and whether motion is real or not.
There are many responces to these questions that go: Well this is not really a meaningful question
because there is no causality involved , that these effects are purely kinmatic effects diue to measurements in relative frames. That motion itself is purely relative with no physical implications whatever.
Well this position may wel be true but is not neccessarily consistent with interpretations that attribute real physicallity to contraction i.e. creating internal tension if occurring within constraints for eg. or in this context seeming to imply actual EM field changes resulting in lattice contraction. You may not actually maintain that view but it could be interpreted from your choice of words.
Once again I have no problem at all with this interprtation and tend to assume the reality of these effects and was basically kidding you on the assumption that you were well aware of all of the above, from many previous threads.
Thanks again for your clear responce
Once you start accelerating the rods around the perimeter they expand since they are not Born rigid, so you could not fit in more than 2*r rods. This is not a valid thought experiment for demonstrating length contraction. The above is a variant of the Ehrenfest paradox and the resolution is the same. Direct experimental verification of length contraction (as opposed to the direct experimental verification of time dilation) is not possible with today's technology. Indirect verification , including the calculation for the length of particle beams and the explanation of the Michelson Morley experiment as viewed from a frame external to the moving Earth (like the Sun) are the only things we have available today.
I see what you are saying. I am always very leery of such discussions. I think that they hinge critically on the various persons' definitions of the words "real" and "physical", which nobody seems to be able to define unambiguously but everybody has a kind of gut feeling that their impression is right and obvious.
Length contraction (and all other relativistic effects) is a coordinate-dependent measurable effect. Some people think that it is measurable so it must be "real" and others think that it is coordinate-dependent so it must not be "real". So I try to avoid ambiguous words like "real" and use well-defined ones like "coordinate dependent" instead.
IMO, the question of the "reality" of length contraction is a purely semantic one which I don't take too seriously.
Yes it is a problem. When I was first introduced to SR I was, wisely, very much influenced by Rindler who in a couple of his earlier books says that length contraction is "real in every sense of the word" which is not very helpful. My sense of the word real may be very different from that of other people. Since learning a little more on the subject I would prefer to say that it is measurable, and that its effect is coordinate dependent because in its own rest frame nothing is happening to length, we are laying our coordinate system on the rest length and coming up with a smaller value.
On the other hand it is theoretically possible (if of course it exists) to demonstrate contraction, by a comparison using three "identical" rods alongside each other. This is probably nearer to most peoples idea of reality
But if we understand the mechanism and can make use of it in our physics then our idea of its "reality" is of no importance except from a philosophical viewpoint.
Matheinste.
matheinste said:
Yes it is a problem. ... My sense of the word real may be very different from that of other people. Since learning a little more on the subject I would prefer to say that it is measurable, and that its effect is coordinate dependent ...
I agree strongly!
Length contraction (and all other relativistic effects) is a coordinate-dependent measurable effect. Some people think that it is measurable so it must be "real" and others think that it is coordinate-dependent so it must not be "real". So I try to avoid ambiguous words like "real" and use well-defined ones like "coordinate dependent" instead.IMO, the question of the "reality" of length contraction is a purely semantic one which I don't take too seriously.
I just want to say that I think your summation above is a masterpeice of rational equivocation and I mean that in a positive complimentary way. it doesn't directly contradict anyone and it neatly and succinctly removes you from the question. :smile:
But,,,,, although I don't have an answer, I do think there is a "real" question to be explored and and I don't think it is just semantic Just MHO
Well, if you can ever formulate the "real" question in a non-semantic way then I think that I would greatly enjoy the resulting discussion.
I do think the question can and should be taken seriously.
There is the thought demonstation, first presented by Dewan and Beran, later retold by John Stewart Bell, usually referred to as 'Bell's spaceship paradox'. Two spaceships, connected by an unstretchable tether of length L, tether fully extended, are initially comoving. They synchronize their clocks. At an agreed point in time they commence acceleration, parallel to the tether, both accelerating at exactly the same G-count. For the tether to not break it would have to decrease the separation between the spaceships. However, since the spaceships meticulously maintain the same G-count the tether will snap.
There is only one physical factor that the breaking of the tether can be attributed to: length contraction.
Hence we have that the principles of SR imply that in specific circumstances length contraction leads to an irreversible result: a tether breaks.
With an irreversible consequence on the table I don't see a way of maintaining that the issue is purely semantic.
This is an inaccurate conclusion about the Bell spaceship paradox. The rope gets stretched or breaks because the trailing spaceship does not accelerate hard enough to keep up with the front spaceship.
We're touching here on the very principle of relativity.
The principle of relativity entails the demand that our explanations of what is taking place must be frame invariant.
For example, prior to relativistic physics the physics of magnet and coil with relative velocity was accounted for differently, depending on whether the magnet was moving with respect to the luminiferous ether, or the coil. Depending on which one is moving (with respect to the ether) a particuler magnetic field(component) is present or not. To the relativist this is an unacceptable state of affairs.
In the case of Bell's spaceship paradox it is not particularly informative to take one particular frame as providing the 'real explanation'. It is not particularly informative to take as point of view the frame instantaneously co-moving with, say, the leading spaceship. Of course, as mapped in the frame instantaneously co-moving with the leading spaceship the trailing spaceship has less velocity. But essentially you're then committing the explanation to one particular point of view, which goes squarely against relativity.
You need to focus on what is common to all inertial frames. The factors that are invariant across the equivalence class of inertial frames are the factors that count.
All what you write is not relevant to my comment and it does not support your statement that the string breaks due to Lorentz contraction.
The Bell Spaceship Paradox is not irrelevant to this topic so I think there is already enough said about it. If you feel an urge to support your statement that the string breaks due to Lorentz contraction I suggest you open a new topic.
That is certainly not the case. In the launch frame it is attributed to length contraction. In the accelerating frame it is essentially attributed to time dilation (which leads to different acceleration profiles as mentioned by Passionflower). And in an inertial frame other than the launch frame it can be attributed to relativity of simultaneity.
Length contraction itself is not semantic, but the question of whether or not length contraction is "real" is purely semantic. As I said before, it is a coordinate-dependent measurable effect. Whether or not such effects are "real" depends on your definition of "real".
OK. You prefer to not enter a discussion about this subject.
His this thread drifted too far from the original entry?
The starting question was whether length contraction has been experimentally confirmed, and around post #10 the talk shifted to wondering whether length contraction should be regarded as physically real; Bell's spaceship paradox bears on the question of what level of physical reality we must attribute.
Just to make sure: you have read my comment in https://www.physicsforums.com/showpost.php?p=2866583&postcount=22" of this thread?
Yes. But not until after I posted.
Then it seemed that you were directly contradicting yourself since this:
Disagrees with this:
Length contraction is not frame invariant so in one post you say it is a factor that doesn't count and in another post you say it is the only factor that it can be attributed to. I don't really want to argue with you until you are done arguing with yourself.
Amount of length contraction is frame dependent, yes. The very occurrence of length contraction effects is the common factor. If there is a force gage at the tether mount then for all frames the prediction for the reading of the force gage will be the same.
Part of this point of view is that loss-of-simultaneity and length-contraction are regarded as one and the same thing. That is, if someone asks, 'is loss of simultaneity real' then I would equally refer to Bell's spaceship paradox as bearing on that question. As we know, during the acceleration phase the two spaceships are out of simultaneity. (Or more precisely, during acceleration no consistent synchronisation procedure exists.)
We have these different expressions for talking about relativistic phenomena: 'relativity of simultaneity' , 'length contraction'. If those are treated as different phenomena then there's room for the view that questioning level of physical reality is semantic.
So I have learned something about my own point of view: I regard loss-of-simultaneity-effect and 'length-contraction-effect as one and the same thing.
I'd expand this to include time dilation as well. All three of (1) length contraction, (2) time dilation, and (3) relativity of simultaneity are consequences of the Lorentz transformation of x and t; going the other way, the three taken together imply the Lorentz transformation for x and t.
Of course, the threesome is one.
We have that unlike moving around in space we cannot make a U-turn in time. Hence the twin scenario can seemingly isolate time dilation from relativity of simultaneity and length contraction.
At the end of the twin scenario the twins are close together again, so their clocks run at the same rate again. By contrast, in Bell's spaceship scenario extension over a large stretch of space is the very subject. You cannot get the appearance of isolation of length contraction the way appearance of isolating time dilation can be achieved.
  • · Replies 45 ·
  • · Replies 63 ·
  • · Replies 83 ·
  • · Replies 33 ·
  • · Replies 18 ·
