| Thread Closed |
row of 1000 integers |
Share Thread | Thread Tools |
| Sep1-10, 12:38 AM | #1 |
A row contains 1000 integers
The second row is formed by writing under each integer, the number of times it occurs in the first row.The third row is now constructed by writing under each number in the 2nd row, the number of times it occurs in the 2nd row.This is process is continued Prove that at some point, one row becomes identical to the next. |
| Sep2-10, 04:41 AM | #2 |
From the second row on, if an integer n is present in the row, then it is present at least n times, because it is the number of times some other number is present in the previous row. If all the different n's are present exactly n times in a row, then all the following rows will be the same (for example (223334444) -> (223334444) -> (223334444) -> ...). If this is not the case, then there must be some n that is present more than n times. This means that going from one row to the next one there are two possibilities: either the row remains the same, or at least some number of the row has a bigger number below it. Since the maximum n that can be present in a row can't be bigger than 1000, this sequence must terminate, and at some point the row doesn't change anymore.
| Sep2-10, 06:57 AM | #3 |
nice one man
| Thread Closed |
| Thread Tools | |
Similar Threads for: row of 1000 integers
| 1 + 10 + 100 + 1000 + ... = -1/9 | General Math | 9 | ||
| Do 1/inf and 1000/inf have same limit of 0? | General Math | 3 | ||
| How many odd integers from 1000 to 9999 have distint digits? will this method work? | Calculus & Beyond Homework | 4 | ||
| My 1000 post | General Discussion | 15 | ||
