Maximum altitude of a rocket engine
The maximum altitude of a rocket launched at a 53-degree angle with an initial speed of 100 m/s and an acceleration of 30 m/s² for 3 seconds is calculated to be 1521.5 m. The total time of flight is 36.1 seconds, and the horizontal range is 4045 m. The calculations provided in the forum discussion indicate discrepancies in the user's approach, particularly in accounting for the vertical and horizontal components of acceleration after engine failure. Correcting these components leads to accurate results consistent with established sources.
  • Understanding of projectile motion and kinematic equations
  • Knowledge of vector resolution in physics
  • Familiarity with trigonometric functions, particularly sine and cosine
  • Ability to apply equations of motion under constant acceleration
  • Review the derivation of projectile motion equations, focusing on vertical and horizontal components
  • Learn about the effects of acceleration on projectile trajectories
  • Study the application of the equation of trajectory: y = xtanA - (gx²)/(2u²cos²A)
  • Practice solving similar problems involving rocket motion and free-body analysis
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators looking for problem-solving strategies in kinematics.
imatreyu
A rocket is launched at an angle of 53 above the horizontal with an initial speed of 100 m/s. It moves along its initial line of motion with an acceleration of 30 m/s^2 for 3 s. A this time its engines fail and the rocket proceeds to move as a free body.
a. Find maximum altitude. =1521.5 m (Correct answer, according to some sources. . .)
b. Its total time of flight = 36.1 s (Correct answer, according to some sources. . .)
c. It's range =4045 m (Correct answer, according to some sources. . .)
I have completed this problem, however my answers do not seem to agree with what the correct answers are supposed to be. The correct answers are noted above. Could someone please point out where I went wrong? I feel like I understand why my process should work, but it's clearly wrong. . .
a.
-The engine stops working at this vertical height: dy =100 sin 53 (3) + 1/2 (30) (3^2)=374.590653
-The rocket's speed after the engines fail is: vf= vi + at = 100 + 30 (3) = 190 m/s
-When the rocket fails, it is still moving at the original angle. Resolved, the vertical velocity is: viy= 190sin53
So: vf^2= vi^2 - 2gd ---> d = -vi^2 / (-2 (9.8)) = 1174.757871
Then, to find the maximum altitude: 1174.757871 + 374.590653 = 1549.35 m
b.
-Time with the engine working is given = 3s.
-Time w/o the engine: vf = vi +at --> 0 = 190sin53 -9.8t --> t= 15.48374968s
-Time to fall: vf= vi + at --> t= vf-vi/a--> t= (squareroot 2ad )/a --> t= (squareroot 2 * 9.8 * 1549.35)/ 9.8 = 17.78184123 s
Adding all three values together = 36.26559091 s.c.
There are two different horizontal velocities: 100cos53 and 190cos53. I solve for both:
For the acceleration period, the horizontal range should be:
dx= 100cos53 (3) + 1/2 (30) 3^2
dx= 315.5445069
For the time after the engines fail:
dx= 190cos53 (33.26559091) + 0 (there is no horizontal acceleration after the engines fail)
Added together, the two values give a horizontal range of= 4119.293656 m.Thank you in advance! I very much appreciate any help given to identify what I am doing wrong!
In First Part you have not taken component of rocket's initial acceleration in y direction
dy =100 sin 53 (3) + 1/2 (30) (3^2)sin53 = 347.406
In Third Part you have not taken component of rocket's initial acceleration in x direction
When engine fails at this point use
y=xtanA-(gx^2)/(2u^2Cos^2A)
A= 53
25K
  • · Replies 17 ·
10K
