Meteorology Differential Equations Problem Help | Boundaries & Constant Epsilon
  • Thread starter Thread starter JerzeyDevil
    Lecture
The discussion centers on solving the differential equation εd²Ψ/dx² + dΨ/dx = -1, with boundary conditions Ψ(0) = 0 and Ψ(1) = 0. The equation is identified as a linear, nonhomogeneous second-order differential equation. The solution process involves first addressing the associated homogeneous equation, deriving the characteristic equation, and then finding both the complementary and particular solutions. Finally, the initial conditions are applied to determine the constants in the general solution.
  • Understanding of linear differential equations
  • Familiarity with boundary value problems
  • Knowledge of characteristic equations
  • Ability to solve for complementary and particular solutions
  • Study methods for solving linear nonhomogeneous differential equations
  • Learn about boundary value problems in differential equations
  • Explore the method of undetermined coefficients for finding particular solutions
  • Review the theory behind characteristic equations and their solutions
Students in meteorology, mathematics, or engineering who are tackling differential equations, particularly those dealing with boundary conditions and nonhomogeneous equations.
JerzeyDevil
Hi, I'm a meteorology major and my professor assumes we know how to do differential equations, and I did at one time, but I have seem to forgotten most of what to do in the past few years. I was just wondering if anyone could help me how to solve this problem...she gave us the answer and the starting point but I can't seem to get the answer she gave:
[tex]\epsilon[/tex][tex]d^{2}[/tex][tex]\Psi[/tex]/dx[tex]^{2}[/tex] + d[tex]\Psi[/tex]/dx = -1
Boundary conditions:
[tex]\Psi[/tex] = 0
[tex]\Psi[/tex] = 0
[tex]\epsilon[/tex] = constant
It may be a bit hard to see in text but its psi(x=0) = psi(x=1) = 0 as the boundary condtions.
Any help would be appreciated!
[tex]\Psi[/tex] = 0
[tex]\Psi[/tex] = 0
Let's get rid of the Greek letters first, to make it easier to type.
The differential equation is Cy'' + y' = -1. This is a linear, nonhomogeneous, 2nd-order DE.
The associated homogeneous DE is Cy'' + y' = 0, and its characteristic equation is Cr2 + r = 0. Solve the characteristic equation for r to get r1 and r2. Your two linearly independent solutions to the homogeneous DE will be er1t and er2t. The complementary solution will be yc = c1er1t + c2er2t
Next, find a particular solution to the DE.
After finding the particular solution, the general solution will be the complementary solution plus the particular solution. Use the initial conditions to find c1 and c2.
I haven't filled in many of the details, since you said you knew how to do this sort of thing at one time. Hopefully this will be enough to get you started.
