Solving Car Stopping Distances and Decelerations
  • Thread starter Thread starter busbus
    Car
The discussion revolves around calculating the stopping distances and required decelerations for a car following another vehicle, particularly at a speed of 60 mph. The original poster presents various scenarios involving reaction times and tailing distances, seeking to understand the underlying physics principles and equations involved.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of formulas for constant velocity and deceleration, questioning how to incorporate reaction times and tailing distances into their calculations. There is an exploration of the relationship between stopping distances and the required deceleration to avoid collision.
The conversation reflects a mix of confusion and attempts to clarify the calculations needed for the problem. Some participants have made progress in their understanding, while others express uncertainty about specific steps and the reasoning behind certain values, such as the total stopping distance and how reaction time affects the calculations.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is an emphasis on understanding the physics concepts rather than simply arriving at a solution.
busbus
I have to write a program that will calculate the distance and/or deceleration needed to stop a car following another. My teacher gave us an example:
(1) When driving at a 60 mph, one covers 44 feet in 0.5 sec.
(2) At 1 g deceleration, one would need 121 feet to come to a stop.
(3) At 2 second tailing, with the 0.5-second reaction time, one would need to decelerate at about 15.3 ft/sec² (0.48 g)
(4) At 11' tailing, deceleration would be 44 ft/sec² (1.38 g)
The first two are easy to understand.
Constant velocity formula is x = v t (where x = distance traveled, v = initial velocity, and t = time).
(This also means that your velocity is 88 feet per second if you are going 60 MPH)
I also know that the deceleration formula is v² = 2 a x (where v = velocity, a = deceleration, and x = distance traveled).
those answer the first two questions.
The second two are killing me because I cannot determine how he arrived at his answers. I realize that the 2-second tailing would be equivalent to 242 feet (at 60 mph) and the 0.5 reaction time would mean I lost 44 feet before I started to decelerate. The 11-foot tailing example has me totally baffled.
I DON'T KNOW WHERE TO START! I think I am thinking about it too much. For (3), I am thinking I need to remove the reaction time distance (44 feet) from my cushion distance (242 feet). That means I started constant deceleration at 198 feet. The guy in front of me will stop at 121 feet. I also know I need to stop in enough time that I do not touch him, so i am subtracting 1 from something. Do I need to stop in, say, 197 feet (242' cushion - 44' reaction time - 1' so I don't crack him) = 197' to come to a stop. But I don't think that is right.
From above, a = v²/2x = (88fps)²/2(198) = 7744 / 396 = 19.55555. I am WAY off!
(4) is impossible for my brain right now...
Wait a minute...I think I need to do something with the stopping distance of the guy in front of me...
I am going 88 feet per second. I am behind him at two seconds. That would be 2 * 88 = 196 feet. (NOT 242 feet!)
It takes me 0.5 seconds to react, so I lose 44 feet right off the bat.
So that means I have 196 - 44 = 152 feet.
The guy in front stops is 121 feet.
Of course, if i decelerate exactly as quickly as him, I would also stop in 121 feet. That means I would be 152-121 = 31 feet behind him...but that is not the answer.
I need the MINIMUM deceleration.
Deceleration = Velocity^2 / (2 * Distance)
Deceleration = 88^2 / (2 * 31) = 7744 / 62 = 124.9999 ARRGGGHHHH!
I am missing something somewhere. I just need a little guidance.
Okay, maybe I got NUMBER 3:
(1) When driving at a 60 mph, one covers 44 feet in 0.5 sec. (88 feet in 1.0 sec)
The deceleration formula is v² = 2 a x (where v = velocity, a = deceleration, and x = distance traveled).
I need to find DECELERATION, so that formula is a = v² / 2x.
Velocity for a car going 60 MPH is 88 feet per minute.
I am also going 60 MPH but I need to stop, say, one foot behind the guy in front.
The distance I need to stop is 242 feet but I need to add 1, so I need 243 feet
v = 88
x = 243 feet
a = v² / 2x
a = (88^2) / (2 *243)
a = 7744 / 486
a = 15.93416
I am getting close...
His is something like 7744 / ((242*2) + 22) = 7744 / (484 + 22) = 7744 / 506 = 15.30435
Where does that 22 come from? Reaction time is 0.5 seconds. That means it took me 44 seconds before I started to brake. Why would I divide 44 by 2??
I think I am way off. I am trying but my logic is all wrong.
PLEASE! JUST A LITTLE NUDGE!
Thanks.
busbus
I figured it out! Thanks for letting me spout off.
Basically:
Determine how much deceleration you need to stop if you were seconds behind the guy in front of you and it took you 0.5 seconds before you put on the brake and started to decelerate
Cushion_Time 2 seconds
Cushion_Distance 176 feet
Reaction_Time 0.5 seconds
Reaction_Time_Distance 44 feet
Distance 121 feet (Stopping distance)
I need to first calculate the Total_Stopping_Distance = (Cushion_Distance + Distance) - Reaction_Time_Distance:
Distance 121 feet
Total_Stopping_Distance 253 feet
Next, use this formula to get DECELERATION:
Velocity 88 Feet_Per_Second
DECELERATION 15.30434783
g 0.47826087
The formula is:
DECELERATION = 88^2 / (2 * 253) = 7744 / 506 = 15.30435.
g = DECELERATION / 32 = 0.47826087---------------------------
Determine how much deceleration you need to stop if you were 11 feet behind the guy in front of you and it took you 0.5 seconds before you put on the brake and started to decelerate
Cushion_Distance 11 feet
Reaction_Time_Distance 44 feet = (Reaction_Time * Feet_Per_Second)
Distance 121 feet
Calculate the Total_Stopping_Distance =
Distance 121 feet
Total_Stopping_Distance 88 feet
Deceleration = Velocity 2 / (2 * Distance)
DECELERATION 44
g 1.375
DECELERATION = 88^2 / (2 * 88) = 7744 / 176 = 44
So I got everything. I'm sorry if I did not explain myself right in here! I get the feeling I did a bad job explaining.
busbus
  • · Replies 19 ·
  • · Replies 33 ·
