Can work function be changed by charge-bias?
The discussion centers on the impact of charge-bias on the work function of tungsten in a hypothetical vacuum tube setup. The work function of tungsten is approximately 4.5V, and the scenario involves applying a 4.0V potential difference across two tungsten electrodes. The key question is whether applying an additional 0.5V of thermal-equivalent heat to the cathode, which is already voltage-biased, will provide conduction electrons with sufficient kinetic energy to escape. It is established that the work function is an energy measurement, and the electric field, rather than voltage potential, influences electron behavior.
  • Understanding of thermionic emission and work function
  • Knowledge of vacuum tube operation principles
  • Familiarity with electric fields and their effects on electron movement
  • Basic concepts of electron kinetic energy and thermal energy
  • Research the principles of thermionic emission in vacuum tubes
  • Study the relationship between electric fields and electron behavior in conductive materials
  • Explore the effects of temperature on electron kinetic energy in metals
  • Investigate advanced vacuum tube designs and their applications in electronics
Physicists, electrical engineers, and anyone interested in the principles of vacuum tube technology and thermionic emission processes.
AshsZ
Hypothetical device:
Vacuum Tube
Two tungsten electrode plates at each end
The work function of tungsten is ~4.5V.
Lets attach a power supply to the two electrodes with a potential difference of 4.0V.
Question is, by biasing the two plates in such manner, is the thermionic discharge potential at the cathode reduced to 0.5V?
rephrase: If 0.5V of thermal-equivalent heat is applied to this already voltage-biased cathode, will the conduction electrons possesses ample kinetic energy to escape?
Vacuum Tube
The work function of a given material is in terms of energy, not potential difference. The thing you also have to remember is that electrons "feel" electric field, not voltage potential. I can have a voltage difference of 4V between two plates, but have their separation be several miles. Clearly that is almost 0 electric field, though, so the electrons won't feel much of a force.
I see. How about in the case of using a much higher voltage power supply with this tube - would make it analogous to a CRT and electrons will flow through the tube, which I know would work. From your description the reason for the flow of electrons is because there is a sufficient electrostatic field between these two plates.
With this modified hypothetical vacuum tube, having a power supply that we can adjust the voltage output, we adjust the voltage just to the point where we can measure a current. Then we back the voltage down just to the point where flow ceases. In this condition, we then add heat to the cathode.
As the cathode increases in temperature, its valence electrons will increase in kinetic energy. Would the combination of the increased electron energy (through heating) and the large electric field that is just below threshold allow the electrons to finally flow through the tube?
  • · Replies 0 ·
  • · Replies 46 ·
11K
