Hovering in gravity makes curved space flat?
The discussion centers on the relationship between space-time curvature and red-shifting in the context of gravity, particularly near black holes. It establishes that red-shifting is influenced by the difference in space-time curvature between the light source and the observer, with the observer's state—whether free-falling or hovering—affecting their perception of curvature. The Riemann tensor is identified as a crucial factor in measuring curvature, while the metric tensor coefficient g00 is used to quantify gravitational redshift. The conversation emphasizes that calling g00 a curvature can lead to confusion, as it is more accurately described in terms of gravitational time dilation.
  • Understanding of general relativity concepts, particularly space-time curvature
  • Familiarity with the Riemann tensor and its components
  • Knowledge of gravitational redshift and time dilation
  • Basic grasp of Schwarzschild metrics and their implications
  • Study the Riemann tensor and its role in general relativity
  • Explore gravitational redshift calculations using the metric tensor coefficient g00
  • Investigate the implications of Schwarzschild metrics on space-time curvature
  • Learn about the effects of velocity on the Riemann tensor in relativistic contexts
Physicists, astrophysicists, and students of general relativity who seek to deepen their understanding of gravitational effects on light and space-time dynamics.
Ray Eston Smith Jr
Have I got it right this time?
Red-shifting is determined by the difference between the space-time curvature at the light source and the observer's space-time curvature.
For the light source, all that matters is the distance from the center of gravity -- I think the motion of the source is irrelevant.
For the observer, if he is free-falling, then his curvature varies with distance from the center of gravity, increasing from flat at infinity to infinite at the singularity.
But if the observer is hovering at rest relative to the center of mass that means that his rocket thrust is unbending the curvature of gravity so that his space-time is made flat -- the same as the space-time of the free-faller at infinity. The distance of the hoverer doesn't matter. Whether he hovers just above the event horizon or at infinity or anywhere in between, his space-time will be flat, because his rockets are exactly cancelling out the gravity-caused curvature wherever he is.
Flat space-time means that there is no net acceleration relative to the center of mass, however it feels like acceleration to the hovering observer -- his reference frame is not inertial. The free-faller at infinity has no net acceleration relative to the center of mass and he feels no acceleration -- his reference frame is inertial.
The difference in curvature between the source at the event horizon and an observer in flat space-time is just enough so that the observer sees time stopped at the event horizon.
In the previous post I neglected to mention that I was talking about red-shifting due to a black hole.
When I said that I think the motion of the source doesn't matter, I should have said that I think the acceleration of the source doesn't matter. Very vast velocity of the source relative to the observer would produce a special-relativistic red-shift. But in this thought experiment, let's say that the source, the free-falling observers, and the hovering observers are all initially at rest with respect to the center of gravity.
This doesn't work as written, but something roughly similar can be said.
*IF* and only if, the metric components are not a function of time,
red shifting is determined by the ratio (not the difference) of the metric tensor coefficient g00 at the source and destination.
Specifically, [tex]\frac{\lambda_{local}}{\sqrt{g_{00}}}[/tex] is a constant when the metric coefficients (all of them) are not functions of time, but only functions of space.
So the ratio between the wavelength measured at point 1 and the wavelength measured at point 2, measured locally in both cases, can be given as the ratio of the square roots of g00 at point 2 and point 1.
g00 should not be described as 'curvature' though. For a static metric, like that around a Schwarzschild black hole, you can think of the redshift between a local observer and an observer at infinity to be a measure of 1/g00^2. You might say informally that g00 is "gravitational redshift", or "gravitational time dilation". Calling g00 a curvature is not right and will cause major confusion.
This is correct.
For the observer, if he is free-falling, [into a black hole] then his curvature varies with distance from the center of gravity, increasing from flat at infinity to infinite at the singularity.
This is correct. The curvature here is a different entity than the g00 that determines redshift (which I mentioned should not be called a curvature). This curvature is known as the Riemann tensor. One specific component of the Riemann can be measured (for instance) by measuring the tension on a 1 meter rod connecting two 1kg masses when the rod is pointed radially. There are a total of 20 components in the complete Riemann tensor. Six of them can be measured by measuring the stretching, compression, and torques on a rod. All 20 of them can be deduced by studying the geodesic paths of nearby observers moving at different velocities.
No. Technically, the Riemann tensor would be measured by "cutting the jets" for a very brief time period to measure the force on the rod. One could also look for the effect of the Riemann without actually cutting out the jets simply by subtracting the known forces due to the acceleration, and looking for any remaining forces which are unaccounted for by the local acceleration.
The Riemann tensor in general can depend on the velocity of the observer. For the special case of a Schwarzschild metric, the radial component of the velocity does not affect the Riemann tensor, so it doesn't matter whether or not the observer is falling in, or momentarily at rest. Velocity components in the other (non-radial) directions do affect the Riemann tensor if they are high enough to be relativistic, even for a black hole.
If I understand this corretly, it's right. I'd say this more succienctly as Flat space-time means no tidal forces.
  • · Replies 30 ·
  • · Replies 62 ·
  • · Replies 34 ·
  • · Replies 84 ·
  • · Replies 17 ·
