How to show group velocity = particle velocity?
The discussion revolves around demonstrating that the group velocity of an electron wave is equal to the particle velocity of the electron. The context involves concepts from relativistic physics, particularly the relationship between energy, momentum, and velocity.
  • Mixed
  • Participants explore the relationship between group velocity and particle velocity using the equation for energy in terms of momentum. There are attempts to manipulate equations involving derivatives of energy with respect to momentum. Some participants express confusion about the definitions of momentum and the implications of relativistic effects.
There are various attempts to simplify or manipulate the equations, with some participants providing hints and corrections. The discussion includes multiple interpretations of momentum and its relation to velocity, indicating a productive exploration of the topic without a clear consensus reached.
Participants are navigating the complexities of relativistic momentum and its definitions, with some expressing uncertainty about the implications of these definitions on their calculations. There is also mention of algebraic identities that may aid in the discussion.
doanta
In an electron wave, show that the group velocity = particle velocity of the electron
E = [tex]p^{2}c^{2} + m^{2}c^{4}[/tex]
[tex] <br /> V_{g} = \frac{d\omega}{dk} = \frac{dE}{dp} = \frac{d}{dp} \sqrt{(p^{2}c^{2} + m^{2}c^{4})}[/tex]
[tex] =\frac{1}{2} \frac{(2pc^{2})}{\sqrt{(p^{2}c^{2} + m^{2}c^{4})}}[/tex]
[tex] =\frac{pc^{2}}{\sqrt{p^{2}c^{2} + m^{2}c^{4}}}[/tex]
after this point I'm stuck, I tried factoring out [tex]m^{2}c^{4}[/tex] and ended up with
[tex] <br /> \frac{p}{m\sqrt{(\frac{p}{mc})^2 +1}}<br /> [/tex]
but I'm still not sure what to do from here. Any help would be greatly appreciated! Thanks
doanta said:
[tex] V_{g} =\frac{pc^{2}}{\sqrt{p^{2}c^{2} + m^{2}c^{4}}}[/tex]
Multiplying both sides by [tex]\sqrt{p^{2}c^{2} + m^{2}c^{4}}[/tex] and then squaring both sides, will have you end with something nicer
Thanks for the hint, however I'm still really stumped on what to do next. I divided and squared both sides and I get this:
[tex] <br /> V_{g}^{2}(p^{2}c^{2}+m^{2}c^{4})=pc^{2}<br /> [/tex]
I've tried subbing in [tex]p=mv[/tex] and I get:
[tex] <br /> V_{g}^{2}(m^{2}v^{2}c^{2}+m^{2}c^{4})=mvc^{2}<br /> [/tex]
Pull out an [tex]m[/tex] and [tex]c^{2}[/tex]
[tex] V_{g}^{2}(mv^{2}+mc^{2})=v[/tex]
and now I'm stuck again =(
You have made a mistake:
[tex]p=\gamma m v\neq mv[/tex]
Sorry, what's [tex]\gamma[/tex]? I've always learned that Momentum = Mass*Velocity?
Relativistic Momentum is redefined as [tex]p=\gamma m v[/tex] where [tex]\gamma = \frac{1}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
(An alternative way to look at it is that mass scales with velocity, that is, that relativistic mass is [tex]\gamma m_0[/tex] where [tex]m_0[/tex] is the object's rest mass, as measured from its rest frame.
Personally I don't like this take on the subject, and greatly prefer the redefinition of momentum instead, since redefining mass as relativistic mass makes for some inconsistent applications of the concept in formulas. Or at least, it is far more confusing than redefining momentum.)
On a related note, you can find that the expression for kinetic energy is [tex]K=(\gamma-1)mc^2[/tex], this is something that can be derived (What is the work you apply to bring a mass from 0 velocity to a velocity v)
A useful algebraic identity for this exercise is [tex]\gamma ^2 = 1+\gamma ^2 \frac{v^2}{c^2}[/tex]
Would this work also?
[tex]V_{g} = \frac{d\omega}{dk} = \frac{dE}{dp} = \frac{d}{dp} \frac{p^{2}}{2m}<br /> <br /> =\frac{1}{2m} \frac{d}{dp} p^{2}<br /> <br /> =\frac{1}{2m} 2p<br /> <br /> =\frac{p}{m}<br /> <br /> =\frac{mv}{m}<br /> <br /> =v[/tex]
You did not square the right side. It should be:
[tex]V_{g}^{2}(p^{2}c^{2}+m^{2}c^{4})=p^2c^{4}[/tex]
