Active Genes & Protein Expression: Why Can't Active Genes Give LacZ Expression?
  • Thread starter Thread starter sotellme
    Genes
The discussion centers on the challenges of expressing the lacZ gene in Saccharomyces cerevisiae when inserted into active genes. It was established that approximately 80% of the yeast genome consists of active genes, which are essential for growth and are always turned on. The professor explained that even if the transposon carrying the lacZ gene is inserted in-frame with these active genes, expression may not occur due to potential interference with protein properties. The experiment yielded fewer blue colonies than expected, indicating that not all gene fusions result in successful lacZ expression.
  • Understanding of gene expression mechanisms in yeast, specifically Saccharomyces cerevisiae.
  • Familiarity with transposon insertion techniques and homologous recombination.
  • Knowledge of the lacZ gene and its role in blue/white screening.
  • Basic principles of protein synthesis and gene regulation in eukaryotes.
  • Research the mechanisms of gene regulation in Saccharomyces cerevisiae.
  • Learn about the effects of transposon insertion on gene function and protein expression.
  • Investigate the role of IPTG in inducing lacZ expression and its application in experiments.
  • Explore conditions that affect gene expression, such as environmental factors and nutrient availability.
This discussion is beneficial for molecular biologists, genetic engineers, and researchers working with yeast genetics, particularly those interested in gene expression and protein function studies.
sotellme
all i learned about protein expression till now is gone, may i say, just because an explanation from my professor...i just hope that he was not right about this, since it turns my "world" up side down!
the aim was to investigate the different expression degrees of the yeast genes. we used S. cerevisiae. we transformed the yeasts with a transposon carrying a lacZ gene. by homolog recombination the transposon with the lacZ gene was inserted into the different yeast genes. we selected for blue colonies. we got different degree of the blue colour. it showed that we got less blue colonies than expected. i asked my professor and he explained;
-> because 80% of the yeast genome codes for active genes ( open reading frames without non sense stop codons) if the transposon was inserted into the active genes then lacZ can't be expressed even if the insertion was in frame with the active genes!
yes, this was what he told me. from my knowledge i thought it does not make any different which genes a DNA segment is inserted into. as long as the fusion is in frame between the different genes, then expression would be! now he said that it does not include active genes. WHY CAN'T ACTIVE GENES GIVE LACZ EXPRESSION?
BTW what kind of genes gave the expression of lacZ we got in this experiment? how can they give the expression of the lacZ?
thanks so much for reading and help!
Biology news on Phys.org
By active genes, you prof meant that about 80% of the genes have functions that essantial for the for the organism to grow. Therefore these genes are virtually always turned on. When you create a gene fusion by using random techniques, like the one you described, the fusion migth have an effect on the protein properties and therefore inhibiting the grow of or killing the organism. Also some genes are only turned on under specific condtions such as low iron, decreased temperature, presence of certain sugars, etc.
It is hard to define what genes would give permit the expression of the genes in the experiment you described. These genes will give a positive reaction with lacZ because this enzyme can fulfill its role even when the with significant amount of amino acid are attach to it. The expression is usually recorded using IPTG, a molecules that mimic lactose.
12K
