The discussion revolves around calculating the density of a 0.7M NaOH solution, exploring different methods and considerations involved in the calculation. Participants address both theoretical and practical aspects of density calculation in the context of solutions.
- Technical explanation
- Debate/contested
- One participant suggests that density can be calculated using the formula d=m/v, providing a method based on the molarity and molar mass of NaOH.
- Another participant calculates the mass of NaOH in 1L of solution and presents density in different units, including g/mL and g/100 mL.
- Some participants argue that previous calculations are incorrect because they do not account for the total mass of the solution, which includes both NaOH and water, emphasizing the need for actual measurements to determine density accurately.
- There is a note that for dilute solutions, density may be close to that of pure water, but for more concentrated solutions, the density will differ significantly.
- One participant points out the lack of clarity regarding the solvent, specifically mentioning that it is not stated that the solution is in water.
Participants express disagreement regarding the correctness of the initial calculations, with some asserting that they are incomplete or inaccurate. The discussion remains unresolved as there is no consensus on the method for calculating density accurately.
Limitations include the assumption that the solution is in water, which is not explicitly stated, and the challenge of determining the exact amount of water in the solution when calculating density.
