How Much Additional Mass Can a Floating Air Mattress Support?
The discussion focuses on calculating the additional mass that a floating air mattress can support, given its dimensions and densities of water and air. The air mattress measures 2.0m in length, 0.50m in width, and 0.08m in thickness, with a mass of 2.0kg. The correct calculation for the additional mass, m, is determined to be 79.9kg, while the initial calculation yielded 78.1kg. The discrepancy arises from the incorrect handling of the density of air in the equation used to solve for m.
  • Understanding of buoyancy principles and Archimedes' principle
  • Familiarity with basic physics equations involving density and volume
  • Knowledge of unit conversions, particularly between mass and weight
  • Ability to perform algebraic manipulations to isolate variables
  • Review buoyancy calculations in fluid mechanics
  • Study the impact of air density on buoyancy in various conditions
  • Learn about the implications of rounding in scientific calculations
  • Explore practical applications of buoyancy in engineering and design
Students studying physics, educators teaching fluid mechanics, and engineers involved in design and analysis of buoyant objects.
mizzy
A rectangular waterproof air mattress is 2.0m long, 0.50mwide and 0.08m thick. It has a mass of 2.0kg and is supporting an additional mass of m, while floating in the water,
calculate the mass, m, assuming the density of water is 1000kg/m^3 and density of air is 1.29kg/m^3
B = weight of displaced fluid
B= density of water x volume * g
where B = mass of 2kg, unknown mass and mass of air
I solved it and i got 78.1kg. The answer is 79.9kg
this is what i did:
m1g + m2g + density(air) * V *g = density(water) * V * g
solve for m2:
m2 = density(water) * V - density(air) * V - m1
m2 = 1000(0.08) - 1.29(0.08) - 2
m2 = 78.1kg
Can someone point out where i went wrong?
No idea how to get answer that you listed as correct, IMHO it is off by 2 kg, but
m2 = 78.1kg
this is just incorrect. Perhaps you have rounded down intermediate results, or just keyed those numbers wrong in your calculator.
800 - 0.1032 - 2 = 77.8968 ≈ 77.9
12K
10K
