How Is the Angle of Displacement Calculated in Vector Travel?
  • Thread starter Thread starter GingerBread27
    Angle Displacement
The problem involves calculating the angle of displacement for a plane's journey from city A to city B and then to city C, covering specific distances in a given time. The context is vector travel, with a focus on magnitude-angle notation for displacement.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the interpretation of "magnitude-angle notation" and the importance of drawing a diagram for vector problems. There are attempts to use trigonometry to find the angle of displacement, with some participants questioning the use of distance versus velocity.
The discussion is active, with participants sharing their attempts at using trigonometric functions to calculate the angle. There is a recognition of potential misunderstandings regarding the values used for calculations, and some guidance is provided on how to approach the problem geometrically.
There is confusion regarding the distinction between distances flown and velocities, as well as the correct interpretation of the angle in relation to the displacement vector. Participants are exploring different ways to express the angle based on the right triangle formed by the displacements.
GingerBread27
A plane flies 400 km east from city A to city B in 45.0 min and then 940 km south from city B to city C in 1.50 h. (Assume i points east and j points north
In magnitude-angle notation, what is the plane's displacement for the total trip
I figured out the displacement is 1021.57 m but i can't figure out the angle. How is this done.
I think what they mean by "magnitude-angle notation" is simply vector notation, so a magnitude and a direction must be given. Did you draw a picture? The first thing you do in a vector problem is draw a diagram, then it becomes easy. Use trigonometry to find the angle.
The answer to the question must be given in m and an angle, so it's not vector notation it's just two numbers straight out. I've tried using trig and keep getting the wrong answer.
show us the trig you've been doing, so we can see where it is wrong...
I've done arctan of 940/400, I've done arctan of 940/400 and tried adding and subtracting 180. It's all wrong.
Why are you using 400 and 940? Those are the distances in km the airplane would fly in one hour[\b]. The problem tells you that the airplane flies east at 400 km/h for only 45 minutes (what distance does it cover?) and flies south at 940 km/h for 1 1/2 hours (what distance does it cover?).
the 400 and 940 are only displacements, they aren't velocities. I thought you found the angle of displacement by using those numbers.
Ah, sorry, you are right. You don't really need the time then- I thought they were speeds.
Okay, If you draw a picture taking θ as the angle "east of south", you have a right triangle with "opposite side" has length 400 km and the "near side" has length 940 km. tan(θ)= 400/940= 0.4225 and so θ= 23 degrees.
Now! How are you writing the angle? As I said, that is 23 degrees "east of south". You could also give it as "67 degrees south of east" (90- 23= 67) or, measured clockwise from north as on a compass, as 157 degrees (180- 23= 157).
  • · Replies 19 ·
