Differentials in the context of thermodynamics
The discussion centers on the interpretation and mathematical understanding of differentials in thermodynamics, particularly in relation to the conservation of energy expressed through state variables such as internal energy (U), temperature (T), entropy (S), volume (V), and pressure (P). Participants explore the implications of these differentials and their application in various thermodynamic scenarios.
  • Homework-related
  • One participant seeks clarity on the meaning of "small" changes in the context of the thermodynamic equation dU = T dS - P dV.
  • Another participant explains that state functions can be expressed in terms of independent variables and that the equation represents a first-order Taylor expansion of internal energy.
  • Further elaboration is provided on how the concept of infinitesimals relates to Taylor expansions, with a focus on the implications of dropping higher-order terms.
  • A participant poses a scenario involving the free expansion of gas and questions how various thermodynamic properties (temperature, pressure, internal energy) are affected by this process.
  • Responses suggest that during free expansion, no energy exchange occurs, leading to implications for changes in internal energy and temperature.
  • Another participant discusses the conditions under which heat (δQ) and work (δW) can be non-zero, emphasizing the necessity of interaction with surroundings for energy exchange.
  • A final question is raised regarding the change in entropy of a spring when it is allowed to decompress by an infinitesimal amount, indicating uncertainty about the relationship between mechanical work and thermodynamic properties.
Participants express various viewpoints on the implications of differentials in thermodynamics, with some consensus on the mathematical treatment of these concepts. However, there remains uncertainty and differing interpretations regarding specific scenarios, such as the effects of free expansion and the relationship between work and heat exchange.
Limitations include assumptions about ideal gas behavior, the definition of infinitesimals, and the specific conditions under which energy exchange occurs. The discussion does not resolve the complexities surrounding these topics.
This discussion may be useful for students and practitioners in physics and engineering who are exploring the foundational concepts of thermodynamics and the mathematical frameworks that describe energy conservation and state functions.
AxiomOfChoice
I just want to make sure I understand differentials in the context of thermal physics. One of the big statements of thermodynamics is the conservation of energy in terms of the state variables [itex]U,T,S,V,P[/itex]:
[tex] dU = T dS - P dV.[/tex]
What does this really MEAN though? Is there any way to understand this in a mathematically rigorous way? People keep explaining it to me like this: "Well, what is means is that a SMALL change in energy is equal to a SMALL change in entropy times..." But "small" is a relative term...so what does "small" mean in this context?
Science news on Phys.org
In mathematical terms, every state function is a function of two independent variables, in your case the entropy and the volume. So for example U = U(S, V). Once you have this functional dependance, which can be found for example using the canonical ensembles of statistical mechanics, you define
[tex]T=\left(\frac{\partial U}{\partial S}\right)_V\qquad\qquad P=-\left(\frac{\partial U}{\partial V}\right)_S[/tex]
and this way the first principle looks the way you wrote it. You can see it as a first-order Taylor expansion of internal energy:
[tex]\Delta U=T\Delta S-P\Delta V+O(\Delta S^2+\Delta V^2)[/tex]
explaining this way the term "small".
In general, when a physics books says that an equality holds for "small" or "infinitesimal" values of the variables, the equality is a Taylor expansion up to some finite order, with all higher order terms dropped. For example, a book might say that f(x)=f(0)+f'(0)x for infinitesimal x. This is stupid for the claim that f(x)=f(0)+f'(0)x+O(x2) in the limit x→0. The "big O" notation is explained here.
If U is a function of two variables, we can define dU as a function of four variables:
[tex]dU(S,V,x,y)=\frac{\partial U(S,V)}{\partial S}x+\frac{\partial U(S,V)}{\partial S}y=Tx-Py[/tex]
and if we call the new variables dS and dV, we have
[tex]dU(S,V,dS,dV)=TdS-PdV[/tex]
where I have used the definitions in Petr's post above. Note that a Taylor expansion of U around (S,V) takes the form
[tex]U(S',V')=U(S,V)+\frac{\partial U}{\partial S}(S'-S)+\frac{\partial U}{\partial V}(V'-V)+\mathcal O(|(S'-S,V'-V)|^2)[/tex]
[tex]=U(S,V)+dU(S,V,S'-S,V'-V)+\mathcal O(|(S'-S,V'-V)|^2)[/tex]
so if we define dS=S'-S, dV=V'-V, then dU(S,V,dS,dV) is the first-order approximation of U(S',V')-U(S,V).
Thanks for your help, guys. I'll busy myself wrapping my head around the things you've said. In the meantime, I'd like to ask a few other questions related to thermal physics:
Suppose you initially have a gas confined, by a partition, to 1/2 of a container (which is isolated from its surroundings). Then you remove the partition and the gas expands to fill the whole container. Certainly, the volume of the gas has changed (it's doubled). But has the temperature of the gas changed? Has the pressure changed? Has the internal energy changed? How do we know?
To solve the simple exercise of the "free expansion" you shall consider (Hp: ideal gas):
-> p, V and T are related by ideal gas law
-> No energy exchange happens during the expansion
-> Energy depends only on temperature
These arguments put a constraint on the final state which allow you to compute it.
Ll.
Ll.
Ok. Well, then I would think the following: No energy exchange implies [itex]\Delta U = 0[/itex], implying [itex]\Delta T = 0[/itex]. The ideal gas law then tells us [itex]P[/itex] decreases by a factor of two...am I right?
I guess another general question I could ask is this: We have [itex]dU = \delta Q + \delta W[/itex] (where the latter two are inexact differentials)...for a given system, can we only have [itex]\delta Q \neq 0[/itex] if the system is able to interact with its surroundings in some way?
Yes, and yes. And besides, if a system is really unable to interact with its surroundings, [itex]\delta W = 0[/itex] as well. That's just energy conservation: [itex]\mathrm{d} U = \delta Q + \delta W[/itex] means that any change in the internal energy must be a result of some energy entering or leaving the system. And there are only two ways for energy to enter or leave: heat and work.
Of course, in principle it is possible to set up a system which can exchange energy by heat transfer but not by work (e.g. enclose it in a rigid, thermally conducting box). Or you could set up a system which can exchange energy by work but not by heat transfer (e.g. an insulating piston chamber).
Ok, thanks. Again, I appreciate all the help.
Now, here's a question I'm not even sure makes any sense...if a spring is compressed some amount beyond its equilibrium length and is allowed to decompress by an infinitesimal amount, is there any change in the entropy of the spring?
  • · Replies 16 ·
