Why Do We Use Integrating Factors in Solving First Order Linear ODEs?
The discussion revolves around the use of integrating factors in solving first-order linear ordinary differential equations (ODEs). Participants express their understanding and confusion regarding the mathematical derivations and the rationale behind the integrating factor method, exploring both theoretical and practical aspects.
  • Homework-related
  • Casey expresses confusion about the difference between indefinite and definite integrals when changing dummy variables, questioning why the integrals differ at all.
  • Another participant clarifies that changing dummy variables does not affect the integral's value, but the limits of integration do, emphasizing the distinction between indefinite and definite integrals.
  • Casey raises concerns about the use of multiple dummy variables in the context of integrals and their roles, seeking clarity on their function in the equations presented.
  • Erik006 shares a similar struggle with understanding the reasoning behind the integrating factor method, noting a lack of explanation in available resources and asking for insights into its origin.
  • Another participant suggests that the product rule is key to understanding the integrating factor, explaining how it can be manipulated to resemble a product derivative, which facilitates integration.
Participants generally express confusion and seek clarification on the mathematical concepts involved, indicating that multiple views and uncertainties remain regarding the understanding of integrating factors and their derivations.
There are unresolved questions regarding the use of dummy variables in integrals and the rationale behind the integrating factor method, as well as the clarity of explanations provided in educational resources.
This discussion may be useful for students learning differential equations, particularly those struggling with the conceptual foundations and mathematical reasoning behind integrating factors and their applications in solving ODEs.
Saladsamurai
Hello all! :smile: I through a section in my text (by https://www.amazon.com/dp/0133214311/?tag=pfamazon01-20) on 1st Order linear ODEs. I am understanding the derivation of the integrating factor method pretty well; however, there are some aspects of the mathematics that I am getting hung up on. I have an "engineering" background in calculus and hence I get slowed down by the details sometimes.
In order to find the solution to an ODE of the form:
[tex]y' + p(x)y = q(x)\qquad(1)[/tex]
we first consider the homogeneous case; i.e.,
[tex]y' + p(x)y = 0\qquad(2)[/tex]
After some hootenanny, we arrive at the solution to (2) given by
[tex]y(x) = Ae^{-\int p(x)\,dx}\qquad(3)[/tex]
Now, in order to solve for the constant 'A' given the initial condition y(a) = b, it says that
"...it is convenient to re-express (3) as
[tex]y(x) = Ae^{-\int_a^x p(\xi)\,d\xi}\qquad(4)[/tex]
which is equivalent to (3) since [itex]\int p(x)\,dx \text{ and } \int_a^x p(\xi)\,d\xi[/itex] differ at most by an additive constant, say D, and the resulting [itex]e^D[/itex] can be absorbed into the arbitrary constant A.
Question 1:
I am not sure why he even brought this up? Why would changing the dummy variables cause the two integrals to differ *at all* ?
Moving on to the homogeneous case:
Basically we wish to multiply (2) by some function of x, say [itex]\mu(x)[/itex] giving
[tex]\mu(x) y' + \mu(x)p(x)y = \mu(x)q(x)\qquad(5)[/tex]
so that the left-hand-side of (5) is a derivative. After much more hootenanny, we arrive at the solution
[tex]y(x) = e^{-\int p(x)\,dx}\left(\int e^{\int p(x)\,dx}q(x)\,dx + C\right)\qquad(6)[/tex]
Now again, if we wish to solve for the constant 'C' given the initial condition y(a) = b, we are again advised to use a different expression of (6), namely
[tex]y(x) = e^{-\int_a^x p(\xi)\,d\xi}\left(\int_a^x e^{\int_a^\xi p(\zeta)\,d\zeta}q(\xi)\,d\xi + C\right)\qquad(7)[/tex]
This is just too much changing of dummy variables for my feeble mind to handle :redface: .
Question(s) 2:
There are 3 dummy variables being used here:
[tex]e^{-\int_a^x p(\xi)\,d\xi}\qquad(8)[/tex]
[tex]e^{\int_a^\xi p(\zeta)\,d\zeta}\qquad(9)[/tex]
[tex]q(\xi)\,d\xi\qquad(10).[/tex]
I am not really sure what is happening here. They are using [itex]\xi[/itex] in (8) and (10) as dummy variables and in (9) as an endpoint of the integral.
I don't expect anyone to answer all of this at once, but i would love to start a discussion about it so that I can solidify my understanding of the derivation. It's not enough anymore for me to just be able *to use* the integrating factor, but instead to *understand it.*
Thanks,
Casey
Anyone have any thoughts or comments? Thanks :smile:
Question 1:
Changing the dummy variables doesn't change anything and that's not what they are saying. The important change is the limits of integration.
[tex]\int p(x)dx[/tex]
without any limits of integration , is the "indefinite integral". If F(x) is an anti-derivative of p(x) then [itex]\int p(x)dx= F(x)+ C[/itex] where C is an arbitrary constant.
[tex]\int_a^x p(\xi)d\xi[/tex]
is an definite integral just with the variable x as an upper limit: with F(x) an anti-dervative as befor, it would be equal to F(x)- F(a). In other words, the "C" is now specifically -F(a).
One good reason for doing that is that a person seeing
[tex]e^{-\int p(x) dx}\int e^{\int p(x)dx}[/tex]
might think, mistakenly, that the two exponentials cancel. They don't of course- you cannot take a function of x "inside" the integral like that.
Question(s) 2:
No, that is not the case. In
[tex]e^{-\int_a^x p(\xi)d\xi[/tex]
[itex]\xi[/itex] is a dummy variable- the integral will be a function of x.
In
[tex]e^{\int_a^\xi p(\zeta)d\zeta[/tex]
[itex]\zeta[/itex] is a dummy variable but [itex]\xi[/itex] is not- this integral will actually be a function of [itex]\xi[/itex] so that it can be integrated with respect to [itex]\xi[/itex] in the outer integral:
[tex]\int_a^x E(\xi)q(\xi) d\xi[/tex]
where "[itex]E(\xi)[/itex]" is the result of the previous calculation,
In that last integral, yes, [itex]\xi[/itex] is a dummy variable- the integration is a function of x.
Thanks,
Casey
I'm learning differential equations, and although I understand the methods I have learned thus far, I often have trouble seeing what is the reasoning behind them.
Take for example, the use of the integrating factor when solving first order linear ODE's. I understand how to use it, but I'm not sure where it came from. In the resources that I'm using there's really not explanation, instead the discussion is limited to: assume there's a function by which we can multiply our differential equation to make it integrable.
Can anybody explain why we use this approach?
thanks,by (Erik006)
thanks,by (Erik006)
I think the key is product rule. namely
(my)'=m'y+my'
Let's say you have a DE
y'+py=q
you want to make it look like product rule by multiplying both sides such that:
my'+mpy=mq
No quite product yet, but if mp=m' then
(my)'=mq
now that y can be solved by integrating both sides. m is very easy to solve given mp=m'.
  • · Replies 0 ·
