Relativistic kinetic energy comapred to Newtonian
The discussion focuses on calculating the speed of a particle whose relativistic kinetic energy (Krel) is 40% greater than its Newtonian kinetic energy (Knew). The equations used include Krel = (gamma - 1)mc^2 and Knew = 0.5mv^2, where gamma is defined as 1/sqrt(1-x) and x = v^2/c^2. The participant initially derived the equation (gamma - 1) = 0.7x, leading to a quadratic equation that resulted in an incorrect value for x. The error was identified as a minor mathematical mistake in the coefficients of the quadratic equation, ultimately leading to the correct speed of v = 0.61c.
  • Understanding of relativistic physics concepts, specifically kinetic energy.
  • Familiarity with the Lorentz factor (gamma) and its calculation.
  • Proficiency in algebra, particularly solving quadratic equations.
  • Knowledge of the relationship between velocity (v) and the speed of light (c).
  • Study the derivation and implications of the Lorentz factor in relativistic mechanics.
  • Learn how to solve quadratic equations effectively, including identifying and correcting coefficient errors.
  • Explore the differences between relativistic and classical kinetic energy calculations.
  • Investigate practical applications of relativistic kinetic energy in high-speed particle physics.
Students and educators in physics, particularly those focusing on relativity and kinetic energy calculations, as well as anyone interested in the mathematical aspects of physics problem-solving.
accountkiller
Find the speed of a particle whose relativistic kinetic energy is 40% greater than the Newtonian value for the same speed.
Krel = relativistic kinetic energy
Knew = Newtonian kinetic energy
Knew = 0.5mv^2
gamma = 1/sqrt(1-x)
x = v^2 / c^2
So I set it up as K(relativistic) = 1.4K(Newton).. because my problem was 40%.
So (gamma - 1)mc^2 = 1.4 (0.5mv^2) and..
(gamma - 1) = (0.7mv^2)/mc^2
... m's on top and bottom cancel out, then I replaced v^2/c^2 by x...
(gamma - 1) = 0.7x
1/sqrt(1-x) = 0.7x + 1
1/(1-x) = (0.7x+1)^2
1 = 0.49x^2 + 14x + 1 - 0.49x^3 - 1.4x^2 - x
0 = x(-0.49x^2 - 1.09x + 0.4)
Using the quadratic formula, I get either x = -3.12 or x = 0.9
Since x = v^2 / c^2,
v = sqrt(x)*c
So I get v = 0.9c
But the answer is 0.61c.
Where did I go wrong?
One of the coefficients in this equation is wrong. (Just a little math mistake)
Ohh man, how did I not catch that? I reworked this three times, with a calculator even, and didn't notice that little mistake.
Thank you so much! I'm relieved it was just a small math mistake. You're a lifesaver :)
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 55 ·
