Solving Summation Question with Floor & Ceiling Functions
  • Thread starter Thread starter mohabitar
    Summation
The discussion revolves around a summation problem involving floor and ceiling functions, with participants exploring different methods to approach the problem, including calculus and graphical interpretations.
  • Mixed
  • Participants question the transition between steps in the problem-solving process and explore whether integration could be applied despite it being a summation. There are discussions about the use of graphs to visualize the problem and the implications of areas under curves.
The conversation is active, with participants sharing their understanding of calculus and its relevance to the problem. Some guidance has been offered regarding the use of integration, but there is also recognition of the need to focus on summation techniques. Multiple interpretations of the problem are being explored.
Participants note the potential confusion between summation and integration, highlighting the need to clarify the nature of the problem. There is an acknowledgment of the original poster's intent to frame the question within a precalculus context.
mohabitar
Not exactly sure how they went from the first step to the 2nd step? Is there an easier way to solve this?
(keep in mind we're dealing with floor and ceiling functions)
There is an easier way to do the problem. You can use what's called integration but that is a calculus topic.
One way you can solve it is by graphing.
You can draw the graph of the function (which is linear) and find the area under the curve. When you calculate the area under the curve (which is a triangle) you only take into account the area from 0 to 30. Also, if any piece of the graph from 0 to 30 is below the x-axis then you have to subtract that portion from the area that is above the x axis.
If you have a graphing calculator I can show you an even simpler way.
I know calculus, I just posted it in here because I thought its a precalc question. How would I use integrals to solve this?
How much calculus do you know?
Lol I'm in Calc II now, will that be enough?
Oh wait...I have to apologize for being retarded. You can't solve this with integration because it's a summation (it's been awhile). Unfortunately, you have to add all those #'s together because a summation is not the exact answer but an estimation. An integral, on the other hand, is the exact answer.
So the question now is, I see that they did it manually in step 1, where its just the sum of all those values, but step 2 I see some multiplication going on-where did that come from?
I get: S[ (i/20 – 1/2) + (i/10 – 1/2 ) ] = S[ i/20 –1/2 + i/10 – 1/2 ] = S[ (3/20)i – 1 ] = 3/20*S -S[1] = 3*(30^2 + 30)/40 – 30 = 39.75
or
S[ (i/20 – 1/2) + (i/10 – 1/2 ) ] = S[ i/20 ] – S[1/2] + S[i/10] – S[1/2 ] = 1/20S – 1/2S[1] + 1/10S – 1/2S = 1/20*465 – 1/2*30 – 1/10*465 – 1/2*30 = 39.75
