Ball in Vertical Circle on End of String, Tangential and Radial Acceleration
The discussion focuses on a physics problem involving a ball swinging in a vertical circle at the end of a 1.30 m rope, with a total acceleration of (-22.5 i + 20.2 j) m/s² when the ball is 36.1° past the lowest point. To find the radial acceleration, the tangential acceleration must first be determined, which is incorrectly assumed to be zero. The correct approach involves recognizing that the j vector does not point towards the center of rotation, as it is oriented at an angle relative to the vertical axis.
  • Understanding of circular motion dynamics
  • Familiarity with vector decomposition in physics
  • Knowledge of acceleration components: radial and tangential
  • Proficiency in using trigonometric functions to resolve angles
  • Calculate radial acceleration using the formula A = v²/r
  • Determine tangential acceleration by analyzing the components of total acceleration
  • Explore the relationship between speed and velocity in circular motion
  • Review the concepts of centripetal force and its application in vertical circular motion
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators seeking to clarify concepts related to acceleration in vertical circles.
xslc
A ball swings in a vertical circle at the end of a rope 1.30 m long. When the ball is 36.1° past the lowest point on its way up, its total acceleration is (-22.5 i + 20.2 j) m/s2.
(a) Determine the magnitude of its radial acceleration.
(b) Determine the speed and velocity of the ball.
A = v^2/r
Ar = Atotal - Atangential
I have no idea where to go with this. I am stuck on the first part. My issue is in figuring out the tangential acceleration so that I can subtract that from the total acceleration to find the radial/centripetal acceleration. My thought is that tangential acceleration should be zero, because the ball is swinging on the end of a string, and its speed should not be changing, only its velocity.
You have a=(-22.5 i + 20.2 j) m/s2. The acceleration vector is made up of the sum of the radial and tangential acceleration. Using your coordinate system, the j vector points up or towards the center of rotation right? So the radial acceleration is?
rock.freak667 said:
You have a=(-22.5 i + 20.2 j) m/s2. the j vector points up or towards the center of rotation right?
no, up is not towards the center of rotation. it is 36.1 degrees past the bottom
  • · Replies 25 ·
  • · Replies 23 ·
21K
