A level Further Pure Maths help (Polynomials)
The discussion revolves around evaluating summations related to the roots of the polynomial equation x^4 - x^3 + 2x + 3 = 0. Participants are tasked with finding values for Σ(a^2), Σ(1/a), Σ(a^2)(B^2), and ΣaB(a + B), using given equations related to the roots.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Some participants express confusion regarding the connection between the summations and the polynomial equation, questioning how the roots relate to the given expressions.
  • Attempts to calculate Σ(a^2) and Σ(1/a) are noted, with some participants successfully finding these values but struggling with Σ(a^2)(B^2) and ΣaB(a + B).
  • There is a discussion about the correctness of a proposed relationship involving ΣaB(a + B) and its derivation from other summations.
  • Clarifications are sought regarding the definitions of the summations and their meanings in the context of the problem.
  • Some participants suggest that the problem may relate to the theory of equations and functions of the roots of a polynomial.
The discussion is ongoing, with participants sharing their attempts and insights. Some guidance has been offered regarding the interpretation of the summations, but multiple interpretations and uncertainties remain. There is no explicit consensus on the correct approach or understanding of the problem.
Participants note that a, B, C, and D represent the roots of the polynomial, but there is still ambiguity regarding the specific meanings of the summations in relation to the polynomial's roots. The original poster and others express uncertainty about the problem's requirements and the relationships between the variables involved.
usman94
Find the values of Σ(a^2), Σ(1/a), Σ(a^2)(B^2) and ΣaB(a + B) for: x^4 - x^3 + 2x + 3 = 0
Σa = 1, ΣaB = 0, ΣaBC = -2, aBCD = 3
I found the Σ(a^2) and Σ(1/a) successfully correct bt could neither find Σ(a^2)(B^2) nor (Σa)(ΣaB):
'ΣaB(a + B) = 6' is given as the answer but my own answer comes 4. Please somebody post the complete solution for ΣaB(a + B) explaining each step, given that i found ΣaB(a + B) = (Σa)(ΣaB) - 2(ΣaBc).
It seems i should have got ΣaB(a + B) = (Σa)(ΣaB) - 3(ΣaBc) in order to get the correct answer '6' instead of the erroneous '4'.
If perhaps this is true, then prove that ΣaB(a + B) = (Σa)(ΣaB) - 3(ΣaBc)
I found Σ(a^2)(B^2) = (ΣaB)^2 - 2Σ(a.B^2.C) - 4aBCD. Now 4m here i can't proceed forward to find Σ(a.B^2.C). Perhaps, i have done it wrong or there exists an alternative easier way.
NB: a,B,C,D represent the roots alpha, beta, gamma and the 4th root (partial derivative sign) respectively.
I don't understand the question. What do the summations have to do with the polynomial equation? That is, how are a and B connected with x^4 - x^3 + 2x + 3 = 0?
ohhh m terribly sorry missing to mention dat. a, B, C and D are the 4 roots of the equation: x^4 - x^3 + 2x + 3 = 0
OK, then what do Σ(a^2) and the other summations mean in the context of this problem?
I'm still clueless as to what this problem is asking for.
these summations are of the roots e.g. Σa means a + B + C + D. Likewise ΣaB represents aB + BC + CD + DA
The first look opens p. 294 of this book. In a quick search I didn't find exercise 9d Q2(d). The attachment in your other thread for this problem doesn't give me enough context to know what the summations are adding.
Are you working on functions of the roots of a polynomial (theory of equations?)
It may be helpful to write the thing out in full and then you will see there are three not two products giving you [tex]\alpha\beta\gamma[/tex]
I think you are agreeing with me (?) that [tex]\Sigma\alpha\beta(\alpha + \beta)[/tex] is just [tex]2\Sigma\alpha^2\beta[/tex]
You can get that out of [tex]\Sigma\alpha\beta\Sigma\alpha[/tex].
= 0 because
[tex]\Sigma\alpha\beta = 0[/tex].
On the other hand [tex]\Sigma\alpha\beta\Sigma\alpha[/tex] also equals in full
[tex](\alpha\beta + \alpha\gamma + \alpha\delta + \beta\gamma + \beta\delta + \gamma\delta)(\alpha + \beta + \gamma + \delta)[/tex]
and there are two products [tex]\alpha^2\beta[/tex] and three products [tex]\alpha\beta\gamma[/tex]
So you've got essentially your answer
[tex]0 = 2\alpha^2\beta - 3\alpha\beta\gamma[/tex]
At first you find them. Later you think you need to look in the first bracket only at the ones without [tex]\delta[/tex]. There are three of them. And they each have their partner in the second bracket to make [tex]\alpha\beta\gamma[/tex]. Later you realize you don't need to look at each of the three because of the symmetry. And you realize there not just are but must be three - and that the [tex]\Sigma[/tex] notation is quite nifty - however you can always fall back on the full formulae if out of practice or something not working.
(I tried to bring them out by colouring the three pairs but it is already rubbish enough to try and write ordinary tex because of defects I mentioned earlier, nearly impossible to edit , however when you write on paper you can use colour underlining if it helps.)
Edit: That last line should be of course
0 = 2Σα2β - 3Σαβγ
  • · Replies 22 ·
  • · Replies 0 ·
