Can the Magnetic Field of a Black Hole Reveal Its Charge and Rotation?
The discussion revolves around the relationship between the magnetic field of black holes and their charge and rotation. Participants explore theoretical implications, observational possibilities, and the nature of fields in the context of general relativity and quantum mechanics.
  • Some participants propose that observing the magnetic field of a black hole could reveal charge density and rotational speed, suggesting a function of charge depending on radius.
  • Others argue that within the event horizon, traditional concepts of charge and magnetic fields may not apply, as anything inside cannot communicate with the outside world.
  • A later reply questions the existence of stable orbits between the singularity and the event horizon, stating that all light cones inside the event horizon direct inward, making orbits impossible.
  • Some participants mention that black holes can generate magnetic fields without being charged, referencing Kip Thorne's work on modeling black holes as conducting spheres.
  • There is a discussion regarding the implications of these magnetic fields in relation to the no-hair theorem, with some suggesting that the magnetic field is associated with matter just outside the event horizon.
Participants express multiple competing views on the nature of black holes, their magnetic fields, and the implications of general relativity. The discussion remains unresolved, with no consensus on the interpretations of charge, rotation, and the behavior of fields near black holes.
Limitations include the undefined nature of singularities in general relativity, the quantum characteristics of spin, and the complexities of gravitational effects on orbits within the event horizon.
Dr Lots-o'watts
By observing the magnetic field of a black hole, couldn't a charge density depending on radius, as well as a rotational speed, be determined? I presume a charge(radius) function can be determined, so that would mean there was mass following a circular trajectories, somewhere between the singularity and the event horizon. Is that right? Is that allowed? What am I missing if not?
Astronomy news on Phys.org
Within the event horizon, I don't believe that concept applies... if you're asking whether or not a BH can have a charge or external magnetic field, then yes it can. Polar jets are (probably) the result of the magnetic field generated by the accretion disk and ergoregion.
The answer is completely undefined and unknown. According to general relativity the singularity has NO physical extent. Also keep in mind the quantum nature of things like 'spin' (e.g. of an electron). Its not associated with an actual rotation/orbit. Just because these ideas apply in casual low gravity, normal scales cases; doesn't mean they apply for black-holes.
The existence of electric or magnetic fields for black holes is usually attributed to the particles "freezing in time" as they fall towards the event horizon with respect to an outside (at infinity) observer, thus freezing the field lines with them. I've always found that description a bit unsettling, but its the best explanation I've ever heard (since clearly anything inside the EH cannot communicate with the outside world).
What isn't unsettling about a BH near the EH? :wink:
Yet couldn't there be mass in "perpetual orbit" (in the same sense as any other orbit), somewhere between the singularity and event horizon? Seems that it would be a very special case if this space was empty.
No. There are no stable orbits any closer than r=6GM/c^2 away from the singularity, and the innermost unstable circular orbit occurs at r=3GM/c^2.
Or if you're interested in a less analytical answer, the simple fact is all light cones inside the event horizon are directed completely inward. So it would be impossible to orbit as you are forced to move inwards (the analogy is that space and time switch roles inside the EH. That is, while you are obligated to move forward in time outside the EH, you are similarly obligated to move inward in radius while inside the EH).
It turns out that black holes like most astrophysical objects can generate large magnetic fields without being charged. Kip Throne worked out the math and if you imagine the black hole as if it were a conducting sphere, you end up with a model that you can use to do calculations of the magnetic field.
But I guess it violates no-hair theorem, isn't it?
Turns out no. What is happening is that the magnetic field is attached to things that are just outside of the event horizon.
the matter falling in them might be.
  • · Replies 17 ·
  • · Replies 44 ·
