How Does Integration by Parts Simplify \(\int 8x^2 \cos(2x) \, dx\)?
The discussion revolves around the integration of the function \(8x^2 \cos(2x)\) using integration by parts. Participants are exploring the steps involved in applying this technique and addressing issues that arise during the process.
  • Mixed
  • Participants discuss the application of integration by parts, with attempts to define \(u\), \(du\), \(dv\), and \(v\). There are questions about the correctness of certain substitutions and the handling of differentials. Some participants express confusion about the presence of \(dx\) in the final expression and the implications of removing it during integration.
The conversation is ongoing, with several participants providing insights and questioning each other's reasoning. There is a focus on clarifying the steps taken and addressing misunderstandings regarding the notation and process of integration by parts.
Participants note the absence of LaTeX formatting and express concerns about the correctness of their expressions and substitutions. There is a specific mention of balancing differentials and the implications of their removal during integration.
Whatupdoc
i will use "\int" as integral signs, cause latex seems to be down.
uv - \int v*du
\int 8x^2cos(2x)*dx
u = 8x^2
du = 16x*dx
dx = 1/16
dv = cos(2x)
v = 1/2sin(2x)
plug in what i found for the formula
8x^2*1/2*sin(2x) - \int 1/2*sin(2x)*16x
take out the 1/2, because it's a number.
4x^2*sin(2x) - 1/2 \int sin(2x) *16x
k this is the part where I am stuck on. do i use integration by parts on the right side agian? my attempt of u-du:
u=16x
du = 16*dx
dx = 1/16
sin(1/8*u) * u
hmm... looks wrong
I find the equation
dx=1/16
to be rather odd.
Also, the lack of a 'dx' at the end of the expression:
seems a bit disconcerting.
That said, what's wrong with dv=sin(2x) in the second parts?
"That said, what's wrong with dv=sin(2x) in the second parts?"
hmm it's suppose to be v=sin(2x)*dx right? not dv. hmm i don't see anything wrong with that part, unless I am missing something.
"I find the equation
dx=1/16
to be rather odd."
yea it's suppose to be dx=1/16*du, it's suppose to balance du right?
how would i solve the integral on the right side? \int 1/2*sin(2x)*16x
another parts sub?
dx=1/16
to be rather odd."
How about dx=1/(16 x) * du so that it agress with the equation above it?
\int sin(2x) * 16x dx
is the same as
\int 16x * sin(2x) dx
which should look somewhat familiar. (yes, parts should work.)
ok i finished the problem, but i can't seem to get it correct.
4x^2*sin(2x) - 1/2 \int sin(2x) *16x*dx
that is what i got so far form the previous post
ok using parts agian...
uv - \int v*du
u = 16x
du = 16*dx
dx = 1/16 *du
dv = sin(2x)
v = -1/2*cos(2x)
ok time to fill in what i know...
16x*-1/2*cos(2x) - \int -1/2*cos(2x)*16*dx
take out the -1/2 and 16 cause it's constant
-8x*cos(2x) +8 \int cos(2x)*dx
find the anti-derv.
-8x*cos(2x) + 4 sin(2x)*dx
put everything together...
4x^2*sin(2x) - 1/2(-8x*cos(2x) + 4 sin(2x)*dx)
4x^2*sin(2x) +4x*cos(2x) -2sin(2x)*dx
ok that's my final answer and it's correct, but the DX is still there... hmm i thought i was suppose to add in 1/16 for dx,cause that's the value that i found
You shouldn't be getting any differentials at the end of the process.
Still no Latex :)
The last integration should be something like:
\int -cos(2x) dx = -1/2 sin(2x)
I'm guessing you did:
\int -cos(2x) dx -> -1/2 sin(2x) dx
(which is incorrect) instead.
Still no Latex :)
yea, but why did the dx get removed?
In an integral, the 'dx' indicates the variable of integration, and where the expression 'inside' the integral ends.
This isn't necessarily the most satisfying answer, but really, the 'dx' gets removed when integration happens because that's the way the notation works. There's probably a historic explanation, and there may well also be an explanation based on differentials, but I haven't seen either. If you like, you could think of the \int as a sort of opening parenthesis and the 'dx' as a sort of closing parenthesis.
For now, it sufficient to know that every time that integration takes place using the usual notation, a differential (e.g. 'dx', 'dt', or 'dθ') gets removed. Integration by parts is a bit confusing in this regard because it's really a shorthand for something like the this:
/int u(x)v'(x) dx =
/int u(x)v'(x) + 0 dx =
/int u(x)v'(x) + (u'(x)v(x) - u'(x)v(x)) dx =
/int (u(x)v'(x)+u'(x)v(x)) - u'(x)v(x) dx =
/int (u(x)v'(x)+u'(x)v(x)) dx - \int u'(x)v(x) dx =
u(x)v(x) + C - \int u'(x)v(x) dx
Although I advise you against it, and it is not standard, you could develop your own notation for integration. On a computer, for example, an integral might look like "integral(f(x),x,a,b)" rather than using the symbols that you're familiar with.
  • · Replies 105 ·
13K
  • · Replies 27 ·
  • · Replies 22 ·
