Cockroft Walton Voltage Multiplier Problems
The forum discussion centers on the challenges faced by a user attempting to build a Cockcroft-Walton Generator for a negative ion generator project. The user aimed for an output of -40kV at 0.845mA using a 5-stage design with a capacitance of 20nF and a 5V input from a function generator at 100Hz. Despite calculations indicating a theoretical output of -40kV, the actual output was only -47VDC, leading to confusion regarding the circuit's performance. The user suspects that the low input voltage and potential misassumptions about load current and capacitance are contributing factors to the output discrepancy.
  • Understanding of Cockcroft-Walton voltage multiplier circuits
  • Familiarity with high voltage (HV) electronics
  • Knowledge of capacitance and its role in voltage multiplication
  • Basic circuit analysis and calculation skills
  • Research Cockcroft-Walton circuit design principles and common pitfalls
  • Learn about high voltage safety practices and isolation transformers
  • Explore simulation tools for testing circuit designs, such as LTspice or Multisim
  • Investigate the impact of load current on voltage output in voltage multiplier circuits
This discussion is beneficial for electronics enthusiasts, students working on high voltage projects, and hobbyists interested in building and troubleshooting Cockcroft-Walton generators.
Fronzbot
Hey everyone.
So I like to have electronics projects going on to keep me on my toes during the academic year and my project I chose for fall ended up being a Cockroft Walton Generator. Basically, I was just looking to make a simple negative ion generator from it. I finally got the parts in today but am having SEVERE problems getting it to work properly or even figuring out what the hell is going on. This is my first HV project, so I'm pretty unfamiliar with this territory. I'm hoping someone out there can help me figure this stuff out.
First, the calculations. I used http://www.blazelabs.com/e-exp15.asp" as a reference.
I wanted an output of -40kV at a current of 0.845mA. I chose 20nF as my capacitance and, as per the suggestion on the site, I made C1 & C2 = nC, C3 & C4 = (n-1)C etc... To save on cost (since I'm a poor college student) I chose 5 stages and was just going to use the input from my Function Generator which has a peak of about 5V and the frequency I settled on was 100Hz.
[tex]V_{out} = 2n * V_{peak} - (I_{load}/(6fC) * (4n^{3} + 3n^{2} - n))[/tex]
[tex]V_{out}= 2(5) * 5 - 0.000845/(6*100*20 \times 10^{-9}) * (4(5)^{3} + 3(5)^{2} - 5)[/tex]
[tex]V_{out} = 50 - 70.4166667 \times 570[/tex]
[tex] V_{out} = -40087.5V[/tex]
[tex]V_{ripple} = I_{load}/fC = 0.000845/(100 \times 20 \times 10^{-9}) = 422.5V[/tex]
So those values were perfectly fine for me. When I attached it up, though, it was only outputting -47VDC. Problem. I tried increasing the frequency and the max output I could get was -101VDC at an 8.3kHz Square Wave. I then added 5 more stages in (Stages 1 and 2 with 100nF, 3 and 4 with 80nF, 5 and 6 with 60nF, 7 and 8 with 40nF and 9 and 10 with 20nF) This time I got it up to -205VDC with an 83.2kHz Square wave.
I'm confused.
I've concluded that my output problem likely lies with the fact that I have such a small input voltage and if the circuit was attached to a more beefy supply, such as mains*, the output would be much greater. I've also concluded that these equations don't make any sense. I see no flaw with my arithmetic and so there are, as I see it, only two possibilities:
1) The equations are wrong
2) I have assumed something I shouldn't (such as Load Current, capacitance, etc)
Number 2 is the more likely case.
So anybody out there that can help me out?
*I should mention that that was just an example. I'm not going to connect this to mains for a few reasons, one of them being I don't have an isolation transformer on hand and another is I don't want to mess around with the mains, especially in my apartment.
By coincidence, another post today has a circuit that might suit you.
See the excellent simulation by Bob S in this thread, :
https://www.physicsforums.com/showthread.php?t=429932
This appears to run at about 150 Hz, but this could be increased by decreasing the value of the 0.39uF capacitors.
You would attach your CW circuitry at the bottom of the diagram, on the secondary of the transformer.
  • · Replies 22 ·
  • · Replies 17 ·
10K
11K
