Fusion in Frame: What Does it Mean?
  • Thread starter Thread starter mountain
    Frame Fusion
The discussion centers on the concept of "fusion in frame" in molecular biology, specifically regarding the fusion of DNA fragments. It is established that for successful fusion, the nucleotide sequences of the DNA fragments must act as independent triplet units to maintain their respective polypeptides. Example 1 illustrates an ideal fusion scenario where both fragments retain their integrity, while Example 2 demonstrates a fusion to avoid, as it results in a reading frame shift and alters the polypeptide structure. Proper planning of nucleotide sequences is crucial to ensure that each fragment can independently form its triplet codons.
  • Understanding of DNA structure and nucleotide sequences
  • Knowledge of triplet codons and their role in protein synthesis
  • Familiarity with plasmid vectors in genetic engineering
  • Basic concepts of reading frames and polypeptide synthesis
  • Research "DNA fragment fusion techniques" for practical applications
  • Study "triplet codon formation in genetic engineering" for deeper insights
  • Explore "plasmid design for fusion proteins" to optimize experiments
  • Learn about "reading frame shifts and their implications" in molecular biology
Researchers, genetic engineers, and molecular biologists involved in protein engineering and DNA manipulation will benefit from this discussion.
mountain
fusion in frame...?
hi guys!
i am new in this field, so i hope that "mature" people can show me the way. thanks in advance!
with fusion in frame does it mean that the nucleotide sequences of both DNA fragments i fuse with each other have to act as independent triplet unit? in this way we can maintain the polypeptide of both DNA fragments? in other words that their nucleotides don't come together to make the triplet codons from the start to the end no matter if the fusion is a C, N or randomly (please see example 1, below).
for instance if the nucleotides of DNA fragment 1 is k's and it is a plasmid and nucleotides of DNA fragment 2 is x's. i insert 2 into 1. should i before the fusion have to make sure that the DNA fragments i fuse have enough nucleotides each to make their own triplets codon?:
example 1: randomly fusion where i insert DNA fragment 2 in the middle of the plasmid:
...kkk kkk kkk xxx xxx xxx xxx kkk kkk kkk...
here we get inframe from the start to the end. is this the ideal fusion? we can see here that the nucleotide sequences of both fragments DON'T COME TOGETHER TO MAKE THE TRIPLET CODONS. they act as independent units. the polypeptides of both fragments are maintained.
example2: in this case i have used a fragment which does not have enough nucleotides to make the triplet codons for its own. that is why it come with the nucleotides of the plasmid to make the triplet codons. AND THIS IS A FUSION WE SHOULD AVOID, RIGHT? because the polypeptides of fragment 2 is changed, so do the plasmid.
...kkk kkk kkk xxx xxx xxk kkk kkk...
i try to shorten this down, but afraid that none will understand my point, so please be patient and read :biggrin:
thanks a lot!
Biology news on Phys.org
Example 1 is usually what you are aiming for fusion protein. In example 2, you would have a reading frame shift which you change the C-terminal of the protein and the mRNA might have a premature stop codon, have no stop codon or the stop codon will be further than the normal frame.
13K
16K
