Thread Closed
Calculating alkalinity and expressing it in "as CaCO3"
Share Thread Thread Tools
Sep20-10, 11:13 PM   #1
Convert the following from milligrams per liter as the ion to milligrams per liter as CaCO3.
A) 83.00 mg/L Ca2+
B) 27.00 mg/L Mg2+
C) 48.00 mg/L CO2
D) 220.00 mg/L HCO3-
E) 15.00 mg/L CO32-
2. Relevant equations
3. The attempt at a solution
I think I did the calculations correctly, but there's a slight difference between my answer and the book's answer...I was hoping someone could look and see if I did the steps correctly and if so is it difference negligible?
A) (83.00 mg Ca{2+} / L) x (1 mmole Ca{2+} / 40.078 g) x (2 meq Ca{2+} / mmole Ca{2+}) x (100 mg CaCO3 / 2 meq) = 207.096 mg/L as CaCO3, book answer = 207.25
B) (27.00 mg Mg{2+} / L) x (1 mole Mg{2+} / 24.305 g) x (2 meq Mg{2+} / mmole Mg{2+}) x (100 mg CaCO3 / 2 meq) = 111.088 mg/L as CaCO3, book answer = 111.20
C) (48.00 mg CO2 / L) x (1 mmole CO2 / 44.0095 g) x (2 meq CO2 / 1 mmole) x (100 mg CaCO3 / 2 meq) = 109.067 mg/L as CaCO3, book answer = 109.18
D) (220 mg HCO3{-} / L) x (1 mmole HCO3{-} / 61.01684 g) x (1 meq / 1 mmole) x (100 mg CaCO3 / 2 meq) = 180.278 mg/L as CaCO3, book answer = 180.41
E) (15.00 mg CO3 / L) x (1 mmole CO3 / 60.0089 g) x (2 meq / 1 mmole) x (100 mg CaCO3 / 2 meq) = 24.996 mg/L as CaCO3, book answer = 25.02
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Sep21-10, 02:59 AM   #2
Admin
Obviously book uses slightly different molar masses. I wouldn't care too much, differences are below 10-3, that's about as precise as you can determine alkalinity experimentally.
Sep22-10, 10:40 AM   #3
alright thank's borek, I thought I would be able to just write it off but that's the farthest off we've ever been, so I figured I'd ask for a second opinion.
Thread Closed
Thread Tools
Similar Threads for: Calculating alkalinity and expressing it in "as CaCO3"
Thread Forum Replies
Calculating diamter of wire that will "blow" if current exceeds 1A Introductory Physics Homework 2
Calculating Speed of Falling Banana - "Just Before" it Hits Ground? Introductory Physics Homework 2
Calculating "Additional" Braking Torque Due To Momentum Classical Physics 15
Difference between "Identical", "Equal", "Equivalent" Calculus & Beyond Homework 9
Calculating the Capacitance of "out of alignment" finite parallel plate capacitors Introductory Physics Homework 1
