Thread Closed
Formal definition of the limit
Share Thread Thread Tools
Sep21-10, 08:10 AM   #1
prove the statement using epsilon delta definition of the limit
lim x->2 (x^3)=8
2. Relevant equations
lim x->a f(x)=L is true when
|f(x)-L|<e
whenever
0< |x-a|<d
3. The attempt at a solution
|x^3 - 8| < e
|(x-2)| |(x^2+2x+4)|<e
x^2+2x+4 has no real roots there for only has one sign f(0)=4 so it is always positive
so |x^2+2x+4|=x^2+2x+4
|(x-2)||(x^2+2x+4)| <C(x-2)<e
where
|(x^2+2x+4)|<C
(x-2) < (e/C) =d
I usually solve most problems like this but I can't find the C
I know that we usually say that d is a small distance so |x-a| <1
|x-2|<1
1<x<3
but then what exactly?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep21-10, 09:36 AM   #2
Recognitions:
Homework Helper Homework Help
don't you want to find C such that [itex] |(x^2+2x+4)| \leq C [/itex] for all x?
Sep21-10, 09:38 AM   #3
yes I am asking how to start that.
also Does it have to be for all x? I mean aslong as I can find a C that works for x that are near two it is enough
Sep21-10, 10:01 AM   #4
how can I relate or change |x-2|<1 to something like x^2+2x+4<C?
if I square it
x^2-4x+4<1
x^2+2x+4<1+6x
I will get a variable not a constant
if I cube it
(x-2)(x-2)^2<1
x^2-4x+4<1/(x-2)
x^2+2x+4<6x+ 1/(x-2)
x^2+2x+4< (6x^2-12x+1)/(x-2)
x^3-8<6x^2-12x+1
this goes in rounds too
I don't know If I got this right but if d is less than 1 then the maximum value of x that can be inputted into x^2+2x+4 is 3
and cant I get C to be (6x^2-12x+1)/(x-2) of 3 = 19
so can't I just say that as long as delta <1 and e/19 the limit is true?
Also what I don't understand about these questions are what delta is necessary for it to be true?I mean I just speculated the solution but what does it mean that delta has to be less than e/19?
Sep22-10, 03:46 AM   #5
Is it because I didn't show enough work that I don't get any replies?
Sep22-10, 05:40 AM   #6
Recognitions:
so we need to show that for any given [itex] \epsilon> 0 [/itex] we can choose a [itex] \delta > 0 [/itex] such that for any x satisfying [itex] |x-2| < \delta [/itex] then
[tex]|x^3 - 8 | < \epsilon [/tex]
so expanding as you have
[tex]|x - 2 |.|x^2+2x+4| < \epsilon [/tex]
now it should be clear (apologies in the other post I put a less than)
[tex]x^2+2x+4 \geq 3 [/tex]
thus we have
[tex] 3|x - 2 | \leq |x - 2 |.|x^2+2x+4| < \epsilon [/tex]
hopefully you can take it from here
Sep22-10, 05:44 AM   #7
Recognitions:
another way to do it would be to work in terms of a variable say d, such that [itex] -\delta < d < \delta [/itex], then you can write the limit as
[tex] |(2+d)^3 - 8| < \epsilon [/tex]
expanding that should allow you to solve for d, making the requirerd relation between epsilon & delta clearer
Sep22-10, 06:23 AM   #8
3|x-2| <e
|x-2|< e/3
so d = e/3 might work?
or did I get it wrong?
I also tried your other method and got |d^3+6d^2+12d|<e but i dont see anything from it.
Sep22-10, 06:47 AM   #9
Recognitions:
that'd do it
the other way was
[tex] |(2+d)(4+4d +d^2) - 8| < \epsilon [/tex]
[tex] |(8+8d+2d^2+4d+4d^2+d^3) - 8| < \epsilon [/tex]
[tex] |(12d+6d^2+d^3)| < \epsilon [/tex]
[tex] |d| |(12+6d+d^2)| < \epsilon [/tex]
similarly
[tex] |(12+6d+d^2)| \geq 3 [/tex]
Sep22-10, 05:29 PM   #10
Homework Helper 2012
Recognitions:
Quote by lanedance View Post
We prove that the limit is 2 if - for any epsilon - a value for d is found so that |x^3-8|<epsilon if |x-2|<d. Unfortunately, we have a complicated expression for d. But remember, both epsilon and d are small numbers, much smaller than 1. So 12+6d+d^2 is certainly overestimated by replacing d with 1. So it is quite sure that d= epsilon/19 will do.
ehild
Sep22-10, 11:17 PM   #11
Recognitions:
not that it changes the idea, but why go to e/19, when you can show it with the looser constraint e/3?
Sep23-10, 12:31 AM   #12
Recognitions:
To get d you need the stricter constraint.
Just try. Let be e=0.1. What should be d so as |(2+d)^3-8|<e?
If you choose d=0.1/3=0.03333 and calculate 2.03333^3-8 it is
0.4 which is much higher than e=0.1. d=e/12 is much better, but the result is still higher than e.
ehild
Sep23-10, 02:53 AM   #13
Recognitions:
yeah apologies, miscalulation on my part
Sep23-10, 05:53 AM   #14
I did figure what epsilon is but I have problems writing it as a formal proof any hints about that?
Sep23-10, 07:20 AM   #15
Recognitions:
You have to find out d can be if you know epsilon. As the definition of the limit is:
"lim x->a f(x)=L is true when
|f(x)-L|<e
whenever
0< |x-a|<d "
Suppose that |x^3-8| <epsilon, a small number (less that 1)
Show you can find some value for d so that in case |x±2|<d |x^3-8| <epsilon is true.
You choose x the farthest from 2 possible: x=2-d and 2+d. Find out the relation which has to be true between d and epsilon.
ehild
Sep23-10, 11:39 AM   #16
Given e>0 we choose d =min{1,e/19} such that to show that 0<|x-2|<d whenever |x^3-8|<e
Thus
|x-2||x^2+2x+4|<e
'.' d<1 , |x-2|<d
,', |x-2|<1
.'. -1<x-2<1
.'. 1<x<3
defining f(x) = x^2+2x+4 = (x+1)^2+3
'.' the vertex of the parabola formed by is at x=-1, the function is increasing for all x>-1,.'. f(1)<x<f(3) 7<f(x)<19
7<x^2+2x+4<19(1)
assuming a constant C=19
|x-2|<d
x^2+2x+4 |x-2|<19|x-2|<e
|x-2|<e/19
choose d min ={1,e/19}
e=19d
then for every
0<|x-2|<d
|x-2|x^2+2x+4<19d=19*e/19=e
thus by definition limit x->2 x^3=8
What are the unnecessary details? what should be added or deleted?
or should I do a completely different format?
Sep23-10, 03:06 PM   #17
Recognitions:
Quote by madah12 View Post
It is the opposite: Given arbitrary small e>0 we choose d such that whenever 0<|x-2|<d, |x^3-8|<e. It is all right otherwise.
ehild
Thread Closed
Thread Tools
Similar Threads for: Formal definition of the limit
Thread Forum Replies
f(z) limit using formal definition Calculus & Beyond Homework 2
Formal definition of limit - Is this a valid proof Calculus & Beyond Homework 0
Formal definition of a limit Calculus 6
Help with formal definition of the limit of a function General Math 9
formal limit definition Calculus 16
