Wiener Deconvolution: Get Clean Signal with Jumps & Bursts
  • Thread starter Thread starter 0xDEADBEEF
    Deconvolution
The discussion centers around the application of Wiener deconvolution to extract a clean signal from measurement data that has been filtered through a low-pass system. Participants explore the spectral power density requirements for both the expected signal and the noise, as well as the challenges associated with deconvolution in the presence of noise and the characteristics of the signal.
  • One participant describes their system as a low pass and seeks to perform Wiener deconvolution on measurement data, expecting a clean signal with jumps and bursts.
  • Another participant questions whether the original signal is known and suggests that if the impulse response is known, applying its inverse directly may be sufficient without Wiener deconvolution.
  • A participant argues that deconvolution can amplify noise due to the low-pass nature of the system, making the Wiener approach preferable as it accounts for the signal-to-noise ratio.
  • There is a discussion about the choice of power spectrum for the signal, with one participant noting that their initial choice did not yield satisfactory results and expressing uncertainty about the appropriate spectral density.
  • Another participant emphasizes the importance of accurately modeling the signal spectrum and suggests measuring the filtered spectrum to inform the Wiener deconvolution process.
Participants express differing views on the necessity of Wiener deconvolution versus direct application of the inverse filter. There is no consensus on the best approach or the appropriate spectral power density for the signal, indicating ongoing debate and uncertainty.
Participants mention the sensitivity of the deconvolution results to the choice of signal power spectral density and the potential for noise amplification when applying inverse filtering. The discussion reflects the complexities involved in accurately modeling the signal and noise characteristics.
0xDEADBEEF
I have a system that acts as a low pass. I know the transient response quite well, and I am trying to do a Wiener deconvolution on the measurement data. I expect a clean signal with a few jumps and bursts. Basically piecewise continuous, with the occasional peak. For the Wiener deconvolution I need the spectral power density of the expected signal, and the spectral power density of the noise.
The noise looks white falling a bit at the high frequencies. Is there a somewhat generic term to use for the spectral power density of a generic signal? Maybe 1/abs(f+epsilon). I could simulate a bit, but maybe someone here has used deconvolution and knows what kind of power densities tend to work well, and how sensitive the outcome is to this.
Also: How well do these deconvolutions work, and what are the biggest problems?
Wait. Are you saying you have an unknown signal x that you are trying to estimate from a filtered noisy version y = x*h + n? And you know the impulse response h (or frequency response H)?
If so, you don't need Wiener's formulism, which attempts to estimate h and its inverse. Just apply h inverse to y (or H^(-1) to Y).
Well, it's not quite as easy. The system lowpasses, and doing a deconvolution puts more emphasis on the high frequencies. But as signals tend to be dominantly in the low frequencies, most of the stuff that gets amplified is noise. So basically the H^-1 applied to N term is too large.
The Wiener deconvolution is damping this effect by weighting the filter with the expected signal to noise ratio. I did a try with a 1/(1 + f^2) power spectrum for the signal but it does not look too good, I think I need more high frequencies.
I am not sure, but it seems to me that by Wiener's formalism you mean blind deconvolution, where the impulse response is iteratively guessed.
No, I was referring to Wiener deconvolution, aka Wiener filter.
It sounds like you have a firm idea of the spectrum of your signal. You say
1) it is predominantly low frequencies, below your filter cutoff
2) a single pole rolling off at 1 Hz removes too much high frequency
BTW, you have answered your question about how sensitive the results are to choice of signal PSD. It matters significantly.
Try a response that corresponds to your understanding of the signal spectrum. Or measure the filtered spectrum directly--if you are right, you'll see signal predominantly at low frequencies, then noise, then the filter rolls everything off. Fit a spectrum to it and use that in the Wiener deconvolution.
  • · Replies 56 ·
