What Liquids Have a Refractive Index Close to Silicone for Flow Visualization?
The discussion centers on identifying liquids with a refractive index close to that of silicone (approximately 1.4) for use in flow visualization studies. Participants explore the possibility of modifying the refractive index of water while maintaining low viscosity and discuss various liquid options.
  • One participant seeks a liquid with a refractive index similar to silicone to minimize distortion in flow visualization, specifically looking for a fluid with the viscosity of water and a refractive index around 1.4.
  • Another participant notes that the refractive index of a substance is not directly proportional to its density, providing an example of oil having a higher refractive index than water.
  • A third participant advises using the term "optically denser" instead of "denser" to avoid confusion between physical density and optical properties.
  • A later reply lists potential liquids with their refractive indices: Turpentine (1.472), Liquid Chlorine (1.385), and Vodka (1.363).
Participants express varying degrees of uncertainty regarding the relationship between density and refractive index, and there is no consensus on a specific liquid that meets the desired criteria for flow visualization.
Participants highlight the complexity of achieving a balance between refractive index and viscosity, with some suggestions potentially leading to higher viscosity than desired.
dtdtdt
I have a transparent silicone model flow chamber which I would like to use for flow visualisation studies. Ideally I would like a fluid whose refractive index is the same as the silicone, hence minimising distortion of the field of view. The refractive index of the silicone model is approx 1.4. Do you know of any liquids which may be of use? Is it possible to change the refractive index of water without a large change in viscosity? I believe refractive distortion greatly depends on the density difference between materials. Is it possible to increase the refractive index by adding a secondary liquid which has low viscosity (i.e. Glycerine works but produces a liquid with a high viscosity)? i.e. I would ideally like a liquid with the viscosity of water and the refractive index of the silicone!
Any help or advice would be appreciated.
Regards
Science news on Phys.org
Yo
I don't exactly know what would work, but just remember that the refractive index of a substance is not proportional to its density. In some cases, a denser substance has a higher refractive index, but not always. For example, oil has a higher refractive index that water.
Hey Christina, Um as i was told by my teacher don't use the term denser, say optical denser, because if it is physically denser it does not necessarily make the refractive index higher, and i lost marks on exams for that mistake... just a little tip :)
And to dtdtdt
As liquids
Turpentine 1.472
Chlorine (liq) 1.385
Vodka 1.363
