| New Reply |
Time dilation and black-hole--black-hole mergers, and ringdown gravitational waves |
Share Thread |
| Sep22-10, 12:56 AM | #1 |
An observer far away from an event horizon never sees a particle cross the event horizon. How does this effect the apparent merger of two black holes?
Also, I've seen that the gravitational waves during the ringdown phase (post-merger) are still periodic. How can this be so, when the trajectory of each BH must be radially inward once it passes the event horizon? |
| Sep22-10, 06:32 PM | #2 |
I could be totally wrong, but it seems to me that the answer to both of these is probably the same. We think of a black hole as having all its "stuff" concentrated at the singularity at the center, but that is only because our usual definition of "stuff" is anything that contributes to the stress-energy tensor. But gravitational fields themselves can carry energy, even though they don't contribute to the stress-energy tensor. In one of these merger processes, you have a region of spacetime that is strongly disturbed, with gravitational waves propagating around in it. These waves have their own dynamics, which continue regardless of the causal disconnection from the region inside the event horizon.
| Aug20-11, 12:54 AM | #3 |
Recognitions:
| Aug20-11, 10:37 AM | #4 |
| Aug20-11, 03:24 PM | #5 |
(b) The "particle never crossing" is the view from a great distance, a stationary non accelerating observer, essentially at infinity....such a perspective does NOT hold near the horizon of a single black hole nor merging black holes. You question is analogous to asking (in special relativity): If two observers in relative high speed motion see each other's clocks are running slower than there own, which is correct? They both are. or analogous in general relativity, "If two distant observers each within different gravitational potentials observe each other's clocks are running different from their own, which is correct? Again, they both are. Since "stretched horizons are not typically discussed here that I have seen, here is what Susskind says about them: Black Hole Complementarity Leonard Susskind, THE BLACK HOLE WAR Complementarity (p238) Today a standard concept in black hole physics is a stretched horizon which is a layer of hot microscopic degrees of freedom about one Planck length thick and a Planck length above the event horizon. Every so often a bit gets carried out in an evaporation process. This is Hawking radiation. A free falling observer sees empty space. (p258) From an outside observer’s point of view, an in falling particle gets blasted apart….ionized….at the stretched horizon…before the particle crosses the event horizon. At maybe 100,000 degrees it has a short wavelength and any detection attempt will ionize it or not detect it! (p270)…. eventually the particle image is blurred as it is smeared over the stretched horizon and….and the image may later be recovered in long wavelength Hawking radiation. (I think this means scrambled information.) |
| Aug20-11, 03:31 PM | #6 |
Of possible interest:
Experimental Clues... |
| Aug20-11, 07:49 PM | #7 |
That's interesting, may I ask you for the source of those quotes?
| Aug21-11, 08:20 AM | #8 |
Looks like I forgot to post the source...Wikipedia...
I just did a quick search and could not find it again...both quotes were from one article as I recall..... I've never seen much of a description of black holes combining...and these were interesting but easily subject to misinterpretation like "When the black hole moves toward Earth, its light is blue-shifted, meaning it has a shorter wavelength..." Huh??..Black holes giving off light?? No, they must mean it's the radiation from infalling matter accelerating into the horizon...but outside the horizon.... such radiation is a key clue to black holes..... |
| Aug21-11, 08:33 AM | #9 |
Always a good idea to name your source when quoting! |
| Aug22-11, 07:47 AM | #10 |
Recognitions:
| Aug22-11, 02:31 PM | #11 |
| Aug22-11, 03:32 PM | #12 |
This seems to be one of the major recent efforts on this:
Phys. Rev. Letters summary: http://arxiv.org/abs/0909.2867 Longer Phys. Rev. D article by the same collaboration: http://arxiv.org/abs/1005.3306 The references link to other key papers, most seem available in arxiv. |
| Aug23-11, 04:22 AM | #13 |
Recognitions:
| Sep10-11, 09:43 AM | #14 |
I am a new guy in this field.....just wanted to know under what conditions does the radial or spiral acceleration of the masses takes place from the event horizon of the black hole......means when does spiral takes place and when the radial takes place......??
| New Reply |
| Tags |
| binary black holes, black holes, event horizon, gravitational waves, ringdown |
Similar discussions for: Time dilation and black-hole--black-hole mergers, and ringdown gravitational waves
| Black Hole Time Machine (time dilation) | Special & General Relativity | 13 | ||
| Black Hole time dilation | General Astronomy | 66 | ||
| Calculating Gravitational Time Dilation in black hole/Future Time Travel | Special & General Relativity | 5 | ||
| since time slows down in a strong gravitational field, does time stop in a black hole | Special & General Relativity | 12 | ||
| Time Dilation and Black Hole Inflation | Astrophysics | 10 | ||
