Why is there a need to average the electric field between capacitor plates?
The discussion revolves around the concept of electric fields between capacitor plates, particularly focusing on the need to average the electric field and the forces acting on the plates. Participants explore the classical understanding of electric fields and forces in the context of capacitors.
  • Participants question the assumptions regarding the electric field inside the conductor and the implications of averaging the electric field between the plates. They discuss the forces acting on the plates and the contributions from each plate's electric field.
The discussion is active, with participants exploring different interpretations of how electric fields interact and the forces they exert on capacitor plates. Some guidance has been offered regarding the nature of forces between the plates, but no consensus has been reached.
There are references to external resources, such as a MIT lecture, and discussions about the implications of the geometry of the plates and the nature of electric fields in this context. Participants are navigating assumptions about the behavior of electric fields and forces in capacitors.
center o bass
As I have understood it, it is a classical problem to show that the force between to capacitorplates is [tex]\frac{1}{2}\epsilon _0 E^2 A[/tex], which is at first counterintuitive since one should think that it is [tex]QE = \epsilon_0 E^2 A[/tex]. I am pondering that question a bit now and i saw the MIT lecture http://ocw.mit.edu/courses/physics/8-02-electricity-and-magnetism-spring-2002/video-lectures/embed07/ where it is explained, but I don't quite get the explanation. When is it ever assumed that the conductor has any with? That is.. is it not only a plane in which it does not have a volume and therefore it is absurd to talk about the electric field inside the conductor?
And why would we ever have to average the two anayway? The efield inside doesn't apply any force. The only force on the plate is from the efield outside and that is certainly E.
Can anyone explain this to me?
You would most certainly agree that the electric field outside the plate is due to both plates. You logic is wrong because a source (even extended one like a plate) can not apply force on itself due to its own field.One simple way to look at this is to assume that the plates have an individual field of E1 an E2. Then inside the plate E1-E2 =0 and outside E1+E2=σ/ε. Solve them and use the field of the other plate to calculate the force on the plate in question.
This result,valid for an infinite plate,is also used to calculate force on the points on a charged conductor due to obvious reasons.
Ah! So what you're really saying is that it's all solved with the fact that the plates can only apply forces to each other?
I have indeed assumed that the total field inside the capacitor exerts a force on a plate, but half of this field is ofcourse due to one plate itself... so ofcourse a particle moving inside that field would experience a force equal to qE, but the plates them selves does ofcourse only experience 0.5QE from each other. Right?
Yes right.
