Understanding Photon Collisions with Solar Sails
The discussion revolves around the mechanics of photon interactions with solar sails, focusing on how photons transfer momentum and energy during collisions. Participants explore the implications of reflection versus absorption of photons and the resulting effects on frequency and energy. The conversation includes theoretical considerations and numerical examples related to solar sail efficiency.
  • Some participants suggest that solar sails act like mirrors reflecting photons, which would imply that reflected photons lose momentum and energy, potentially resulting in a lower frequency.
  • Others argue that solar sails may absorb photons and re-emit them as heat, which could also lead to a loss of energy and a lower frequency.
  • A numerical example is provided to illustrate the forces involved when sunlight impacts a solar sail, comparing perfectly reflective and perfectly absorbent materials.
  • Some participants discuss the Doppler effect, noting that the frequency of reflected photons may change depending on the motion of the mirror, affecting energy transfer.
  • There is speculation about the possibility of creating a "photon trap" that could theoretically harness energy from photons without them losing energy, raising questions about the conservation of energy in such a system.
  • Concerns are raised about the conditions under which a solar sail can effectively absorb energy, particularly when considering the motion of the sail and the initial conditions of the photon interactions.
Participants express differing views on whether solar sails primarily reflect or absorb photons, leading to multiple competing models regarding energy transfer and momentum conservation. The discussion remains unresolved with no consensus on the mechanisms at play.
Participants acknowledge the complexity of photon interactions with solar sails, including the dependence on the material properties of the sail and the orientation relative to incoming light. There are also unresolved aspects regarding the mathematical treatment of energy transfer and the conditions under which these interactions occur.
This discussion may be of interest to those studying solar propulsion, photon dynamics, or the physics of light-matter interactions, as well as individuals curious about the practical applications of solar sails in space exploration.
gonzo
I have some questions about solar sails. Basically, what happens to the photon?
I am under the impression that the "sail" is a giant mirror that reflects photons striking it. Since photons have momentum, they impart some of this momentum to this mirror. Is this correct?
But that must mean that each photon loses momentum/energy. Does this just mean that the reflected photons will always be of a lower frequency?
Does anyone know what determines during a photon collision with another particle how much momentum is transferred as opposed to other collision effects?
Thanks.
Astronomy news on Phys.org
I don't think it's a mirror intended to reflect photons. It's a material that "captures" that momentum. The photon is absorbed & perhaps re-emited away as heat (lower frequency). (Sure, there's some reflection like anything else.)
the most efficient solar sail would be reflective, like a mirror.
if it bounces the photon directly back then it captures about twice as much momentum as if it absorbs the photon
(this is just conservation of momentum)
we can do a numerical example, assume we have a square meter of mirror-like mylar that is impacted by a kilowatt of sunlight. perpendicularly.
if it is perfectly reflective, the force in Newtons will be 2000 W/c
2000/3E8 Newtons = 666E-8 = 6.7 E-6 = 6.7 microNewtons.
but if it is perfectly absorbent (black) then the force will be 1000 W/c
3.3 microNewtons.
the doppler effect means that the photon that is reflected has longer wavelength (from the standpoint of a stationary observer who sees the mirror moving and being accelerated) and so the light gives up energy
but if you position yourself on the mirror and say that the mirror is at rest
then the light just bounces off, in a direction depending on how the mirror is oriented, and momentum must be conserved.
I guess the picture is pretty much like a sail. One might tilt it 45 degrees to the sun and use it to gain orbital speed. then the analysis would be slightly more complicated than if the light is striking perpendicular
I guess all there's left to do is find out which material has the best reflectiveness to density ratio.
Mylar gift wrap!
:smile:
I've been thinking about this now, and I can't help thinking that it still seems like you are getting free energy if the photon doesn't lose energy.
It seems to me that if the photon is just reflected at the same frequency that you could theoretically construct a free energy machine that consisted of a "photon trap" with two mirrors just bouncing photons back and forth between them, and use the slight movement of the mirrors from the photons hitting them to gain energy.
If the photons never lost energy, they could in theory bounce back and forth forever.
What am I missing?
gonzo said:
I've been thinking about this now, and I can't help thinking that it still seems like you are getting free energy if the photon doesn't lose energy...
...What am I missing?
say you are the stationary observer and the light energy (as well as the mirror motion) is being measured on your intruments on your terms
then the energy books are going to balance because every little bit
of kinetic energy that is imparted to the mirror
is balanced by a doppler downshift in the energy of the light after it hits the mirror.
I am not proving this to you with algebra, or even declaring it to you as some kind of "authority". I just want to throw the idea your way so you can see if it works for you.
I think, for me, it works. I don't even have to check the algebra.
as the mirror moves back faster and faster it soaks up more and more energy from the light that is bouncing off it
and that fits the kinetic energy formula with its 1/2 m v2
of course in order to take energy the mirror has to be free to move
(otherwise it is like the wall you bounce tennis balls off of, they keep their energy almost because the wall is connected to the huge mass of the earth
so the wall barely moves when it is hit and the amount of energy it absorbs is negligible)
so it looks like you are considering sometimes a special case where the mirror is almost not moving----maybe because you just begin to accelerate it by shining the light on it. You ask how then can it absorb energy because there is almost no doppler shift?
Well as the mirror is just beginning to move it is also absorbing almost no kinetic energy.
when V is zero (at the very outset) then the Delta E is zero, because the kinetic energy has the V-square term.
I think you should consider a more typical case where the mirror is already moving some.
thanks marcus
I thought the "sail" was powered by solar "wind" {particles} and not light
http://science.nasa.gov/ssl/pad/solar/sun_wind.htm
  • · Replies 26 ·
  • · Replies 16 ·
15K
  • · Replies 35 ·
9K
