Minimum Size of Connected Subgraph in Graph Theory | Help with u and v in G
The discussion revolves around determining the minimum size of a connected subgraph in a graph G that contains two distinct vertices, u and v. Participants explore the properties of connected subgraphs, the definitions of size, and the implications of the distinctness of u and v.
  • Some participants propose that any connected subgraph containing u and v must include a set of vertices and edges that are connected.
  • There is uncertainty regarding whether "size" refers to the number of edges or the number of vertices in the subgraph.
  • One participant suggests that if u and v are adjacent, the minimum size could be 1, but this is challenged by others.
  • Another participant notes that a connected graph requires a path between every pair of vertices, implying that the smallest connected subgraph must contain a path from u to v.
  • It is discussed that the smallest connected subgraph containing u and v cannot have a path of length 1 since u and v are distinct, leading to the conclusion that the minimum length must be at least 2.
  • A participant presents a specific graph example to question the assumption that the minimum size is always two, suggesting that the answer may vary based on the graph's structure.
Participants express differing views on the minimum size of the connected subgraph, with some arguing for a minimum size of 2 while others challenge this notion with examples. The discussion remains unresolved regarding the definitive minimum size across different graph structures.
There is ambiguity in the definition of "size" as it could refer to either the number of edges or the number of vertices. Additionally, the implications of distinct vertices and their connectivity are not fully resolved.
Kipster1203
Let u and v be distinc vertices in a connected graph G. There may be several connected subgraphs of G containing u and v. What is the minimum size of a connected subgraph of G containing u and v?
and does this suggest another question?
Any connected subgraph containing u and v has to contain a set of vertices/edges satisfying what property?
that they are connected.
Size is the number of edges right? So if the subgraph only contained adjacent u and v, then wouldn't the minimum size be 1?
I already said the subgraph is connected. What does it mean for that to be true?
Size can be referring to either the number of edges or the number of vertices depending on context. I'm not sure which one they mean here, but it turns out to be the same answer regardless
The number of vertices is the defined as the order of a graph.
A graph is said to be connected when a path exists between every pair of vertices?
And a path is a special kind of a connected graph. So every connected subgraph containing u and v contains a path from u to v, which means the smallest connected subgraph must be...
a path of length 1?
Kipster1203 said:
a path of length 1?
That probably doesn't exist (unless u and v are connected)
Oh because it says u and v are distinct, so the smallest that could exist would have length 2
Consider the following graph
http://www.cs.ucr.edu/~neal/2005/cs141/wikidb/uploads/cut_vertices.png
Ignoring the other stuff on the pictures, what's the size of the smallest connected subgraph containing a and h? It certainly isn't two; that implies that they are connected by an edge
yes, that is one example. But the question asks for the minimum size.
I'm confused. Yes, it's an example, and the point is that the answer is not always two
