Calculating Percent Uncertainty for Volume of a Beach Ball
The discussion revolves around calculating the percent uncertainty in the volume of a spherical beach ball, given its radius and associated uncertainty. The original poster is seeking to understand the relationship between the radius and the volume in the context of uncertainty calculations.
  • The original poster attempts to calculate the percent uncertainty using the radius directly, questioning how to incorporate the volume formula and the uncertainty in the radius into their calculation.
  • Some participants suggest that the percent error in volume is related to the percent error in the radius, prompting further exploration of the relationship between these quantities.
Participants are exploring the relationship between the radius and volume in terms of uncertainty. Some guidance has been offered regarding the proportionality of volume to the cube of the radius, and the discussion reflects a mix of understanding and confusion about applying these concepts correctly.
The original poster expresses a desire to understand the calculations rather than simply obtaining the answer, indicating a focus on the underlying principles of uncertainty in measurements.
Melissa
hi, I'm attempting a physics problem... it is:
What, roughly, is the percent uncertainty in the volume of a spherical beach ball whose radius is r= 2.86 plus or minus 0.09 m.
Now, I tried to find the percent uncertainty by just doing .09/2.86, but I'm assuming I need to do something with the radius (in the way of changing it to the full volume...) before I can calculate this.
I know that to find the volume it would be 4/3 pi R cubed, but after that... how does the volume correlate to the .09? Does that need to be altered as well? I know the answer is 9% but I would like to actually understand how the question is done!
I'm just confused. Any help would be greatly appreciated!
General Rule : When quantities multiply, the relative errors in those quantities add up.
The volume is proportional to the cube of the radius. As a result the percent error in volume is thrice the percent error in the radius.
ok... so since I cube the radius, I multiply the % error by 3...
ah. and that gives me 9%.
You are a genius. Why must physics profs supply us with pages and pages of calculations when you can solve a problem like THAT instead...
13K
