Thread Closed
Thermodynamics: water in a piston-cylinder device
Share Thread Thread Tools
Sep25-10, 11:23 AM   #1
A piston–cylinder device initially contains steam at
3.5 MPa, superheated by 5°C. Now, steam loses heat to the
surroundings and the piston moves down hitting a set of stops
at which point the cylinder contains saturated liquid water.
The cooling continues until the cylinder contains water at
200°C. Determine (a) the initial temperature, (b) the enthalpy
change per unit mass of the steam by the time the piston first
hits the stops, and (c) the final pressure and the quality (if
mixture).
2. The attempt at a solution
a. is easy... I lookup Tsat@3.5MPA in a table and add 5°C to it.
b) we are looking for h2-h1 where h2 is hf@3.5MPA,Tsat and h1 is hg@3.5MPA,Tsat+5
c) This is where Im stuck. I only have one intensive property, which is temperature=200°C. I need to find another one to find the state of the final water. Since it is impossible to tell whether or not we have a mixture with the temperature and the pressure only, I am guessing the other intensive property I need to find is the specifc volume. However I have no idea how to do that.
After the piston hits the stops, the volume is constant and the pressure changes. Thus, if at 200°C we still have some gas, then obviously the final pressure is Psat@200°C. However, I can't tell if we still have some gas.
Can anyone please help
Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Thread Tools
Similar Threads for: Thermodynamics: water in a piston-cylinder device
Thread Forum Replies
Closed system piston cylinder device problem Introductory Physics Homework 3
Thermodynamics: Piston-Cylinder Engineering, Comp Sci, & Technology Homework 8
Thermodynamics- work in a cylinder piston device with spring Engineering, Comp Sci, & Technology Homework 4
Thermodynamics - Piston Cylinder Biology, Chemistry & Other Homework 0
Thermodynamics - Energy analysis of piston-cylinder device Mechanical Engineering 2
