What Angles Should the Nozzle Point to Reach 3.0m?
The discussion focuses on determining the angles at which a fire hose nozzle should be pointed to achieve a horizontal distance of 3.0 meters when water is shot at a speed of 6.8 m/s. The equations of motion for projectile motion are applied, leading to the conclusion that the nozzle should be positioned at angles of 32.6 degrees and 57.4 degrees. The calculations involve using horizontal and vertical displacement equations, factoring in gravitational acceleration of 9.8 m/s². The final angles are derived from solving the resulting equations.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions (sine, cosine, tangent)
  • Basic knowledge of kinematic equations
  • Ability to manipulate algebraic equations
  • Study the derivation of projectile motion equations
  • Learn about the effects of air resistance on projectile trajectories
  • Explore the use of graphing calculators for solving trigonometric equations
  • Investigate real-world applications of projectile motion in engineering
Students studying physics, engineers working on fluid dynamics, and anyone interested in the practical applications of projectile motion principles.
lmf22
physics projectile problem...
A fire hose held near the gound shotts water at a speed of 6.8m/s. At what angle(s) should the nozzle point in order that the water would land 3.0m away?
It asks for 2 different angles.
Any help would be great. Thank you.
Make an equation showing the time spent in the air using the distance formula. This is overall vertical distance (0).
d = Vi*t + (1/2)*a*t^2
d is 0, Vi should be 6.8*sin(theta), a is just -9.80. Try to isolate the time. From the looks of it, the time will equal something * sin(theta).
From there, do horizontal distance
d = Vi*t
d is 3, Vi is 6.8*cos(theta), and t is the equation created above. You should end with sin(theta)*cos(theta) = something. From there you can probably just graph it.
To solve this physics projectile problem, we can use the equations of motion for a projectile:
1. Horizontal displacement (x) = initial velocity (v) * time (t) * cos(theta)
2. Vertical displacement (y) = initial velocity (v) * time (t) * sin(theta) - (1/2) * acceleration due to gravity (g) * time (t)^2
3. Final velocity in the horizontal direction (vx) = initial velocity (v) * cos(theta)
4. Final velocity in the vertical direction (vy) = initial velocity (v) * sin(theta) - g * time (t)
Given:
Initial velocity (v) = 6.8m/s
Horizontal displacement (x) = 3.0m
Vertical displacement (y) = 0m (since the water is landing on the ground)
Acceleration due to gravity (g) = 9.8m/s^2
Substituting these values into the equations, we can solve for the time (t) and the angle (theta).
1. x = 6.8 * t * cos(theta)
2. y = 6.8 * t * sin(theta) - 4.9 * t^2
3. 3.0 = 6.8 * t * cos(theta)
4. 0 = 6.8 * t * sin(theta) - 4.9 * t^2
Solving for t in equation 3:
t = 3.0 / (6.8 * cos(theta))
Substituting this value of t into equation 4:
0 = 6.8 * (3.0 / (6.8 * cos(theta))) * sin(theta) - 4.9 * (3.0 / (6.8 * cos(theta)))^2
Simplifying:
0 = 3.0 * tan(theta) - 4.9 * 0.132 * sec^2(theta)
Using a calculator or graphing the equation, we can find that there are two possible angles:
theta = 32.6 degrees and theta = 57.4 degrees
Therefore, the nozzle should point at an angle of 32.6 degrees and 57.4 degrees in order for the water to land 3.0m away.
  • · Replies 20 ·
