Why Does Newtonian Physics Say About Object Motion and Forces?
The discussion revolves around fundamental concepts of Newtonian physics, specifically focusing on object motion and the forces acting on them. Participants explore questions related to inertia, forces, and the effects of opposing forces on motion, with a particular emphasis on understanding the implications of net force and acceleration.
  • Homework-related
  • One participant poses a series of questions regarding the principles of motion and forces, seeking validation of their answers.
  • Another participant asserts that all answers are correct except for the last question regarding the effects of opposing forces on a particle.
  • There is a discussion about whether the net force acting on a particle, subjected to two equal and opposite forces, results in a state of constant velocity or deceleration.
  • Some participants suggest that the original force continues to act, which may lead to confusion about the resulting motion when a second force is applied.
  • One participant expresses uncertainty about the net force and its implications for the particle's motion, leading to a reevaluation of their answer.
  • Another participant clarifies that when the second force is applied, the net force becomes zero, prompting a reconsideration of the particle's state of motion.
  • Ultimately, a participant concludes that the object would continue at its speed when the second force is applied, based on the understanding of net force and acceleration.
Participants exhibit disagreement regarding the interpretation of forces acting on the particle. While some argue that the particle would decelerate, others contend that it would maintain its speed due to the net force being zero. The discussion remains unresolved as different viewpoints are presented without consensus.
Participants express confusion over the conditions of the forces applied and the resulting net force, indicating a need for clarity on the assumptions regarding the continuous application of forces and their effects on motion.
Beginners in physics, students seeking clarification on Newtonian mechanics, and individuals interested in understanding the principles of motion and forces in a conceptual context.
PhysicsNovice
Can someone help me with these questions. I am a beginner in the study of physics and would like some help. I have attempted to answer these but would like to know if I am correct and a brief (very brief) explanation. Thanks in advance for your assistance.
An object maintains its state of motion because it has:
a) *mass
b) weight
c) speed
d) acceleration
e) all of these
One object has twice as much mass as another object. The first object also has twice as much:
a) *Inertia
b) Velocity
c) gravitational acceleration
d) volume
e) all of these
A hockey puck is set in motion across a frozen pond. If ice friction and air resistance are neglected, the force required to keep the puck sliding at constant velocity is:
a) *zero Newtons
b) equal to the weight of the puck
c) the weight of the puck divided by the mass of the puck
d) the mass of the puck multiplied by 10 meters per second per second
e) none of these
A 10-N falling object encounters 10 N of air resistance. The magnitude of the net force on the object is:
a) *0 N
b) 4 N
c) 6 N
d) 10 N
e) none of these
The force required to maintain an object at a constant speed in free space is equal to:
a) *Zero
b) the mass of the object
c) the weight of the object
d) the force required to stop it
e) none of these
Neglecting friction, a large block of ice and a small block of ice start sliding down an incline together. The
heavier block will get to the bottom:
a) before the light block
b) after the light block
c) *the same time as the light block
Suppose a particle is accelerated through space by a 10-N force. Suddenly the particle encounters a second force of 10 N in the opposite direction of the first force. The particle is:
a) *brought to a rapid halt
b) decelerates gradually to a halt
c) continues at the speed it had when it encountered the second force
d) theoretically tends to accelerate toward the speed of light
e) none of these
All correct except this last one.
e) none of these
When that second force acts, what is the net force on the particle?
Thanks Doc Al. Is the answer (b) decelerates gradually to a halt? The original force of 10N accelerated the object and brought it to a constant velocity. The object would stay at this speed and direction until an unbalanced force acted upon it. At this point the new 10N force applied in the opposite direction would decelerate the moving object a eventually bring it to a halt. I am so confused!? What do you think?
You might want to rethink this, nowhere in the problem does it say that the first force ever stops being applied to the object.
I am even more confused. Can someone explain? I re-read the question with the clue above in mind. The original 10 N force is constantly applied to the object causing it to accelerate. When the second 10N force is applied to the object in the opposite direction of the original the object will slow slightly but continue to accelerate. Is the answer (d) d) theoretically tends to accelerate toward the speed of light? Thanks for the help.
Right.
When that second 10N force is applied: what is the total force on the object?
0 Newtons? I am not sure.
Eactly right. The force is now zero. So... what's the right answer?
Doc Al. You have been the only one helping me. Thanks, I feel like I will owe you tutorial service fees. Anyway, after your last reponse I am ready to change my answer to (c) continues at the speed it had when it encountered the second force. His is my new reasoning: A constant 10 N force is applied to the object causing it to accelerate as the force is continually applied. At the moment the second 10 N force is applied in the opposite direction the net acting force is 0 N. At that moment the object would stop its acceleration and the object would continue its speed that it was at the time the second force was applied. If this is correct I do understand this completely. What do you think?
You got it!
I'm very expensive. :smile:
Exactly right.
  • · Replies 22 ·
  • · Replies 29 ·
  • · Replies 51 ·
  • · Replies 21 ·
  • · Replies 29 ·
