Maxwell's idea to measure aether
  • Context: Graduate
  • Thread starter Thread starter ghwellsjr
    Aether Idea Measure
The discussion centers on Maxwell's proposal for measuring the aether's relative velocity with respect to the solar system, specifically through the observation of the speed of light during the eclipses of Jupiter's satellites. Participants explore the feasibility and implications of Maxwell's idea, as well as its relation to earlier experiments like those conducted by Römer and later by Michelson and Morley.
  • One participant references Maxwell's statement about measuring the relative velocity of the aether using observations of Jupiter's satellites and questions whether this has been previously discussed.
  • Another participant suggests that if the Earth has a specific speed through the aether, measuring the speed of light from Jupiter at opposite points could yield differing values, potentially indicating the Earth's motion through the aether.
  • A participant elaborates on Maxwell's proposal, hypothesizing that it involved measuring the one-way speed of light at different times as the Earth moved toward and away from Jupiter, raising questions about the accuracy of distance measurements and the feasibility of such an experiment.
  • Another participant recalls Römer's method of estimating the speed of light by comparing timing of eclipses of Jupiter's moons at varying distances and suggests that Maxwell's idea might involve a similar approach but with different angles of observation.
  • A later reply questions whether Maxwell intended to replicate Römer's experiment with greater precision or if he had a different methodology in mind, indicating uncertainty about the specifics of Maxwell's proposal.
Participants express differing interpretations of Maxwell's proposal and its feasibility, with no consensus reached on whether he aimed to replicate Römer's experiment or if he had a distinct approach. The discussion remains unresolved regarding the implications of Maxwell's ideas and their potential outcomes.
Participants note limitations regarding the accuracy of distance measurements and the conditions necessary for Maxwell's proposed observations, as well as the historical context of earlier experiments that may have influenced his thinking.
ghwellsjr
On this webpage http://www.mathpages.com/home/kmath241/kmath241.htm" are these words of Maxwell:
"The only practicable method of determining directly the relative velocity of the aether with respect to the solar system is to compare the values of the velocity of light deduced from the observation of the eclipses of Jupiter’s satellites when Jupiter is seen from the Earth at nearly opposite points of the ecliptic."
First off, has this been discussed on this forum?
Secondly, what exactly was Maxwell proposing?
And finally, assuming that the technology were available to Maxwell, could he have measured something that would have led him to the wrong conclusion?
Assuming that the Earth has a specific speed through the ether, then measuring the speed of light coming from Jupiter (or any object) at opposite points on the ecliptic would, under the right conditions, give values differing by twice the speed of the Earth through the ether. Since Michaelson and Morley did similar experiment not long after (on the surface of the earth, not using Jupiter) I imagine that the technology was sufficient (certainly people were getting accurate values for the speed of light using the eclipses of the moons of Jupiter). What he would have gotten would, of course, have been a null result- that the motion of the Earth through the ether, if any, was too small to measure.
I guess I should have asked a more detailed question. Let me provide some more background and try to get at what I am looking for.
Maxwell's idea was to measure the one-way speed of light at two different times, one when the Earth was moving toward to Jupiter and six months later when the Earth was moving away from Jupiter. MMX measured the difference in the speed of light between two round-trip paths at the same time but in two different directions 90 degrees apart. Their experiment was actually practicable and I fully understand it but I'm not sure Maxwell's was because I don't fully understand what he was proposing.
I think maybe what Maxwell was proposing basically amounted to observing a distant clock and measuring the time interval between "ticks" of that clock when moving toward it and then when moving away from it and calculating the speed of light, knowing the distance that the light traveled in both cases, taking the difference. But I don't know how he could know the distance accurately enough to draw any conclusion and I don't know if this would even work in principle.
So maybe his idea was that he would have a stable clock on Earth and what he wanted to measure was the "drift" in the tick rate the distant clock as the Earth moved toward it and then away from it.
So what I'm looking for is a detailed explanation of what he was proposing to measure and what he was hoping to conclude and if his experiment could have measured something that would have lead him to a false conclusion, again assuming that he had even more precise instruments than we have today.
Recall that Römer first calculated (an estimate of) the speed of light by comparing the timing of Jupiter's eclipses when the line of sight from the Earth to Jupiter is across the Earth's orbit (i.e. when Jupiter and the Earth are more or less "furthest" from each other), versus when the line of sight is in the opposite direction (i.e. when Jupiter and the Earth are more or less "closest" to each other).
I suspect that Maxwell's suggestion meant to repeat this procedure twice, with lines of sight at right angles to each other. This would (hypothetically) give different speeds of light for the two directions, relative to the solar system.
Thanks for the reply. However, see this article:
http://en.wikipedia.org/wiki/R%C3%B8mer%27s_determination_of_the_speed_of_light"
If I understand it correctly, the observations of Jupiter's moon can only be done near the the 90 degree points already, in other words, as per your second suggestion (at right angles to the first suggestion) and it was no where near accurate enough for Maxwell to have used Römer's data.
But you bring up a good point: was Maxwell simply proposing to repeat Römer's experiment with greater accuracy or did he want to do something different?
  • · Replies 32 ·
  • · Replies 58 ·
  • · Replies 19 ·
  • · Replies 24 ·
23K
  • · Replies 23 ·
  • · Replies 38 ·
10K
