Calculus-Volume of tetrahedron and cross product
The discussion centers on determining the coplanarity of points A = (1, 2, 3), B = (1, 1, 1), C = (1, 0, 2), and D = (2, -2, 0), and calculating the volume of the tetrahedron formed by these vertices. The correct volume is established as 5/6, indicating that the points are not coplanar. The professor's calculation, which yielded a volume of 3, was based on an incorrect application of the cross product and the volume formula for a tetrahedron. The scalar triple product and determinant method were discussed as accurate approaches to confirm these results.
  • Understanding of vector operations, specifically cross product and scalar triple product.
  • Familiarity with the volume formula for a tetrahedron: V = (1/6) * base area * height.
  • Knowledge of determinants and their application in vector geometry.
  • Ability to calculate vector differences to determine edges of a tetrahedron.
  • Study the scalar triple product and its geometric interpretation in vector calculus.
  • Learn how to compute the volume of a parallelepiped using determinants.
  • Explore the relationship between coplanarity of vectors and the determinant being zero.
  • Practice problems involving the volume of tetrahedrons and coplanarity using various sets of points.
Students preparing for calculus exams, educators teaching vector geometry, and anyone interested in mastering the concepts of volume calculations and vector coplanarity.
GingerBread27
Determine whether the points A = (1, 2, 3), B = (1, 1, 1), C = (1, 0, 2), and
D = (2,-2, 0) are coplanar and find the volume of the tetrahedron with vertices
ABCD.
My professor did this problem in class as a review for an upcoming test and he didn't get the answer that was on the key. He just chuckled and went on but I would like to know how to really do this problem.
The answer should be 5/6 and the points are not coplanar. My teacher got the answer of 3. He did the cross product of a and b times c. He got the cross product of a and b to be -3 and multiplying -3 by c resulted in -3. He used the volume of a tetrahedron to be (1/6)ha, h being C and area being a cross b.
Draw a picture! The area of a parallelgram is "base times height". If you know the lengths of two connected sides, say x and y, and the angle. θ, between them, then the height (measured perpendicular to the base) is y sin(θ). The base is x so the area is xy sin(θ).
One way of defining the cross product of two vectors, u and v, is that it is the vector with length |u||v|sin(θ) (theta is the angle between the two vectors).
If one side of a parallelogram is the vector u and the other is v, then the length of the sides are |u| and |v| so that the area is |u||v|sin(&theta), exactly the same as the cross product: the area of a parallelogram whose sides are the vectors u and v is exactly the cross product of u and v.
ABCD.
Have you learned about scalar triple product? it is
a.[bxc] You can look after at Mathworld, for example.
http://mathworld.wolfram.com/ScalarTripleProduct.html
You can calculate the volume of a parallelepiped defined by the three vectors a, b, c. This product is the same as the absolute value of a determinant D, built up from the components of the vectors :
| ax ay az |
| bx by bz |
| cx cy cz |
D = ax by cz + ay bz cx + az bx cy - az by cx - ay bz cx - ax bz cy .
Now, the edges od the tetrahedron are not the original vectors
A, B, C, D , but the differences, for example with respect to B.
a = A-B = (0, 1, 2)
c = C-B = (0, -1, 1)
d = D-B = (1, -3, -1)
If these three vectors are coplanar the points A, B, C, D are in the same plane.
In this case the volume of the corresponding parallelepiped is zero.
So we calculate the determinant.
| 0 +1 +2 |
| 0 -1 +1 | = 0 +1 + 0 + 2 +0 + 0 = 3
| 1 -3 -1 |
The volume of the parallelepiped is 3. The volume of the corresponding tetrahedron is one sixth of this value, that is 3/6=1/2.
As I understood you, this is the same what your teacher got.
That key might be wrong...
ehild
  • · Replies 36 ·
